Badger5JMB Retrofits
Results 1 to 17 of 17
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    Clunk on reverse!! What is it??
    Cars really good but noticed after having been driving and stop to select reverse, (got DSG) then after moving back about 2 feet I hear a clunk, every time! Only once and seems to come from the front to middle-ish part of the car underneath. Never happens going forward, only when first going backwards. Is this normal with DSG?? or a problem starting to show??
    thanks
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    I had the same problem once. Turned out it was my neighbours cat.
    Second time it happened it turned out to be their dog.
    I heard the same noise the other week but didn't stop to see what happened.
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    Sarah's A3's Avatar
    5,923
    Quote Originally Posted by V6Pete View Post
    lol, you nutter!!! lol
    V6Pete's Avatar
    Feb 2009
    Northants
    1,492
    Quote Originally Posted by Sarah's A3 View Post
    Oi! You have no proof it was me that killed their little boy. Somebody else might have done it.
    scottie123's Avatar
    Oct 2008
    1,888
    Pete, you're carzy
    Sarah's A3's Avatar
    5,923
    Take it no one knows then????
    scottie123's Avatar
    Oct 2008
    1,888
    perhaps it is a dsg thang, as mine doesn't do it !
    So I cant comment I'm afraid
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    Could it be something to do with the Quattro drive/reverse selector?
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    Apr 2009
    Florida (previously Liverpool)
    655
    No bicyclists pressed up against your rear window, or anything???
    My DSG doesn't do it... dass all I can tell ya.
    Could be brakes, could be a few things, would probably need to go an alift to check some usual suspects though...
    Keef
    27,126
    Could be a brake pad in caliper tbh as yours are 345mm iirc & I have the same setup & had similar issues until I put some 3M padding in the pad caliper location which stopped the clonking, needs the wheels of & a nose in the calipers & test for movemnet in pads.
    Sarah's A3's Avatar
    5,923
    Thank you, will check tomorrow! appreciated
    Sarah's A3's Avatar
    5,923
    Quote Originally Posted by VWAddict View Post
    Keef
    lol, no cyclists lol. I'm not that bad at driving lol.
    Oct 2009
    Plymouth, Devon
    71
    Hey guys it sounds like the mecatronics unit (gearbox control unit) gone faulty we had a shed load in a while back all complaining of the fault above and some hesitating when pulling away hope this helps
    27,126
    When you say we, as in dealer? If so which one & were these changed under warranty & what age of cars please?
    Sarah's A3's Avatar
    5,923
    Hiya, thanks for that. As NHN asked, were they done under warranty??? And did you mean it can also do it going forwards too??? Is this a fault that can get progressively worse??
    thanks
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    562
    I have the same clunking noise problem also when reversing. Notably, the clunk only occurs when applying the accelerator in reverse. If allowing my S3 to coast in reverse the clunk does not occur. As others have said, it may be a DSG type niggle as I have had this behaviour since 8 miles on the car....
    You can take the boy out of Essex but not Essex out of the boy...
    Oct 2009
    Plymouth, Devon
    71
    Hi yeah it'll be covered under warranty providing it's in the warranty period ie less than 3 years old and under 60,000 miles with a dsg oil change done at 40,000 that's the important one I'm at my local vw dealer in the south west we had a stage not long ago where we were stacked out the door with them on all dsg models
