ElsaWin anyone? looking to change Alternator Bearings
Von Maximo
The Damned
South Yorkshire
As the title suggests my bearings have acquired a squeal when stated in morning and sounds a bit rattly when running warm so think it's on it's last legs.
If anyone has got Elsawin and wouldn't mind helping me out by emailing me a PDF on exchanging bearings I'd be most appreciated!
Thanks in advance
Be supprised if that is covered as I would expect the standard procedure to be change the whole unit, but I could be wrong.
Paul
Doubt very much if you can get just the bearings but I might be wrong.
The squeal on starting is often associated with a slack belt - worth checking.
cheers
Fossie
Just checked Elsawin and ETKA parts catalogue and alternator bearings do not appear in either manual.
However, a Bosch unit for a 2.0 litre diesel is listed as £370 so I'd either keep looking or get a replacement from a motor factor !!
Good luck
Fossie
21
8K
658
AndyA3170
A
12
5K
Ads
