Badger5Sky Insurance
Results 1 to 12 of 12
    a3slinedaz's Avatar
    Dec 2009
    rattlling kids sweet!!!
    hi people, does anyone know how i can take the back seat out of my a3? or at least lift it up as one of the kids has pushed a sweet down the back of the seat and now its rattling on the metal work underneath whenever i go round bends and its driving ME round the bend! just phoned audi and they said it'ld be 65!!!!!!!!!!!!!! to get one bloody skittle out!
    mdre83's Avatar
    Aug 2007
    South East
    629
    Quote Originally Posted by a3slinedaz View Post
    Lift front of rear seat bench -1- and pull out rear seat bench to front.
    Installing
    NoteTake care not to damage plastic inserts -3- (2x) during installation.
    Engage anchoring lugs -2- (2x) in plastic inserts -3- (2x).
    Press down rear seat bench -1-.
    I would chnage your text font too mate, little hard to read
    Hope this helps.
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    a3slinedaz's Avatar
    Dec 2009
    thanks mate much appriciated!
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Sorry to hijack this thread, but how do you take out the other part of the rear seat? The parts you can fold down?
    a3slinedaz's Avatar
    Dec 2009
    i can see why they want 65, ill be buggered if i can get that seat out as it says in the diagram!
    mdre83's Avatar
    Aug 2007
    South East
    629
    Left (1/3) section of backrest and right (2/3) section of backrest without centre armrest - exploded view of components
    1 - Mounting bracket (right-side)
    2 - Latch (right-side)
    q Removing and installing → Chapter
    3 - Centre bracket
    4 - Clip
    5 - Trim cap
    6 - Bolt, 15 Nm
    7 - Mounting bracket (left-side)
    8 - Pivot pin (left-side)
    9 - Latch (left-side)
    10 - Left (1/3) section of backrest
    11 - Right (2/3) section of backrest
    q without centre armrest
    12 - Pivot pin (right-side)
    Right (2/3) section of backrest with centre armrest - exploded view of components
    1 - Cup holder
    q In centre armrest
    2 - Centre armrest
    3 - Belt buckle
    4 - Bearing
    q For backrest
    5 - 55 Nm
    6 - Three-point seat belt (rear)
    7 - Backrest latch
    8 - 12 Nm
    9 - Latch trim
    q For backrest latch
    10 - Head restraint guide
    11 - Head restraint guide
    q With release tab
    12 - Belt guide
    q For three-point seat belt
    13 - Covering frame
    q Cannot be removed without becoming damaged
    14 - Right (2/3) section of backrest
    15 - Foam wedge
    16 - Cover and padding
    17 - Load-through hatch
    18 - 10 Nm
    q With plastic ring
    q Cannot be renewed as a separate unit
    19 - Padding
    q For centre armrest
    Removing and installing left (1/3) backrest section or right (2/3) backrest section
    Removing
    – Remove luggage compartment floor covering.
    – Release retaining clips -arrows- at cover cap.
    – Remove bolt -1- and detach retaining clip -2- in direction of -arrow-.
    – Lift backrest out of mounting (centre).
    – Pull backrest out of outer pivot pin towards centre of vehicle.
    Installing
    Install in reverse order of removal.
    I hope this helps...
    Khufu's Avatar
    West coast of Scotland
    5,693
    Its very easy after the 1st time you do it, after you have pulled up you do need to push it towards the rear of the car quite hard to clear the rear hooks or it can get tangled the wrong side of them.
    Dec 2008
    London
    340
    a3slinedaz, i'll give you a tip...Its hard to explain but I got the hang of it!
    Start from the back 2 corners, dig your hand under the back and push the seat 'backwards' (towards the boot) whilst pulling it up at the back corner. Do this for each corner then only the front 2 clips are holding it. I just yanked the seats out from these. hard. lol
    Theres only 4 clips holding the seat down, the 2 back ones are like hooks, hence you need to push them back towards the boot whilst at the same time pulling up. Hope that helps!
    a3slinedaz's Avatar
    Dec 2009
    thanks guys, ill give it another go. my fingers have recovered now from earlier lol
    Nov 2008
    Surrey
    147
    I've got one of those rattles but mine sounds like someone has left a socket in there. You can hear it rattle but when going slow over speed bumps I can hear it rolling backwards and forwards...MMmm might have to have a look under the back seat now...
    A3 3.2 DSG S-line
    Khufu's Avatar
    5,693
    You'll manage fine, just send the 65 to Ewan, paypal account number ................. LOL
    Fossie
    Rhubarb Triangle
    3,969
    mdre83 - please tell me how you get elsawin diagrams posted in the forum. I've tried many times but copy/paste, converting to pdf etc. which is the limit of my ability, does not work.
    Thank you
