Chris NottEM Tuning
Results 1 to 13 of 13
    bambam's Avatar
    Sep 2009
    South West
    123
    New to forum and already have problems!
    Hi there,
    Recently picked up an A3 2.0 TDi Sport 140 as my Impreza + 3000 miles/m = the need for an oil refinery to follow me around!
    Had a look around a couple of forums and this ones seems to be the most lively / friendly place so thought I'd join.
    Got a couple of issues with the 'new' A3 though, first of which I'm going to tackle is the washer jets not working (front or rear).
    I've had a very quick search and not found much on windscreen washer jets not working, mainly just problems with the rear.
    Any suggestions of the best place to start looking?
    Is there a manual available for the 8P A3 - or even better an online manual available.
    Thanks very much.
    warren_S3's Avatar
    Oct 2007
    6,170
    Sounds like the pump (or the fuse for the pump) have failed to be getting nothing front and rear.
    Some cars on this platform have issues with rear wash wiper pipes popping off after big freeze, but for both sets seems unlikely.
    Not sure there is a manual about (certainly that I know of).
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Welcome to the forum!
    Did you buy the car privately? Or was it from car dealers? You should get it fixed by the place that sold you the car, unless you knew about the fault from the seller and took the car .
    Get it scanned to see what fault codes it comes up with. One of the members with VCDS might be living in your area.
    Here's the link:
    ***VCDS Users Map***
    VCDS USER
    Fossie
    Rhubarb Triangle
    3,961
    Elsawin electronic service manual for all VAG cars try here :-
    http://cgi.ebay.co.uk/ELSAWIN-3-7-VW...item3a5909e4b2
    bambam's Avatar
    Sep 2009
    South West
    123
    Thanks for the quick replies.
    Fuses was going to be my first port of call.
    I dont have the manual to hand, does anyone have a copy of the diagram to show which fuse controls washer motor. Does it control other functions also as I could diagnose if other items are not working correctly.
    Thanks for the VCDS link, is great that there is a community to help you out!
    bambam's Avatar
    Sep 2009
    South West
    123
    Quick (newbie) question, whereabouts is the fuse box?
    Have read about a panel on the side of the dash but I dont seem to be able to locate it (either drivers or passenger side).
    Am I just being dense or is it located elsewhere on my car? It's a 2003 model 2.0 TDi 140 Sport.
    TIA
    warren_S3's Avatar
    Oct 2007
    6,170
    I thought there was a fuse box under the bonnet next to the battery (passenger side near back of the engine bay). The back of the fuse box panel 'should' have a list of the fuses on it(?)
    The old 8L series A3 had fuses behind the end panel on the dashboard (driver side). You had to stick a flat blade screwdriver in and prize off the end of the dash panel (mounted on spring clips)
    Fossie
    Rhubarb Triangle
    3,961
    It's still there on the 8P ! Drivers side dash end panel - carefully prise off with flat bladed screwdriver.
    bambam's Avatar
    Sep 2009
    South West
    123
    Hmmm doesnt seem to be any end panel on mine...both end of the dash are the same and securely located...
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Both ends are the same but they will both pop off... the fuses are right hand end and will pop off with a screw driver..
    May 2009
    south yorkshire
    569
    its definately under the end panel on the drivers side, easy enough to prise it off with end of car key
    bambam's Avatar
    Sep 2009
    South West
    123
    Thanks very much!
    Had a look last night.
    Dual washer pump - fuse missing
    Heated rear window - fuse missing
    Reinstated the relevant fuses and all sorted now.
    Rear washer doesnt work but am assuming this will be due to a split pipe or the pipe becoming disconnected somewhere so I'll have to locate that.
    Thanks again for your help guys!
    Fossie
    Rhubarb Triangle
    3,961
    If the pipe has come off you need to replace it before using the washers again. For obvious reasons the inside of the boot lid will become waterlogged !
