Chris NottVolks Autos
    Joe90k's Avatar
    Speed doesn't Kill!
    Apr 2009
    229
    Help with OEM Bluetooth - Mic not working!
    I have just fitted my OEM bluetooth today, it works fine except the Mic is not working, I have tried swapping the polarity but still nothing. It is all new apart from the module.
    Could the mic itself be faulty? On advanced measuring blocks on VCDS it reads as no real voltage drop when the mic is plugged in (Around 7.8V) Could the Mic be broken? Or the module damaged somehow? (Short circuit Mic wires maybe??)
    Any help would be great. I think I am going to order a new Mic tomorrow from Audi to rule that out.
    Joe
    Click above for my A3 Build thread!
    Apr 2009
    Florida (previously Liverpool)
    655
    OPEN circuit... not short.
    Short would drop to ZERO volts DC when connected.
    Try a different microphone. -I bought a standard electret condenser microphone module to diagnoe my problem, and while the volume was a few dB quieter, it showed me that the problem was my microphone.
    Try a 1kΩ resistor between the pins also... if no voltage drop still, try a paper-clip. If that doesn't take the mic input to ground, check that they've wired the mic to th ecorrecxt pins on the connector, and also measure for continuity, to eliminate a bad pin-crimp also.
    Keith
    Apr 2009
    655
    Also... do you have a fluke meter? -I measured about 8VDC with the mic unplugged, which would also help prove the mic wiring ...
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Quote Originally Posted by VWAddict View Post
    Keith
    Hi Keith,
    I know this post is old and you may no longer even be on this forum, but can you tell me if I should see the voltage drop as I speak into the Mic? Not sure if my Mic is faulty or not but my Audi Phone Prep no longer hears me. nor do people I'm on a call with. VCDS shows my Input Voltage to be between 4.5 and 6.5 V with a current of around 0.002 A.
    I've ordered a new Mic as a precaution so I can prove one way or the other.
    Cheers.
    After 3 BMWs in over 13 years, I'm giving Audi a go.
