JMB RetrofitsBadger5
Results 1 to 12 of 12
    Jul 2009
    37
    Lots of white smoke when starting my A3 2.0TDi 54plate..
    Had few problems with my a3 recently, but now when I start it it doesnt go straight away sounds like its struggling, then when it goes it puffs out alot of white smoke diesely/oil smelling.
    Any ideas? x
    Jul 2009
    37
    Also what should she be idling at on cold start?x
    Fossie
    Rhubarb Triangle
    3,969
    Are you losing coolant quite quickly as well ? If you are, it could be the famous 'porous head' syndrome which that engine (BKD? ) suffered from around that time. Water gets into the cylinders and causes cold start problems and white smoke. Try using K-Seal leak sealer which you pour direct into the expansion tank. Worth a try at 10 a bottle ! Mine idles at 850 approx on cold start. Hope this helps
    Jul 2009
    37
    No have never lost coolant *touchwood*
    Mine idles at around 900 but when first started it tends to have a big mis fire every few seconds up to about 1000rpm..
    Fossie
    Rhubarb Triangle
    3,969
    That sounds like good news not having any coolant loss.
    Maybe a Vagcom scan would show up something - I'm sure someone on here will be able to help you.
    I'm afraid I'm not expert enough to help any further - sorry.
    Good luck
    May 2009
    south yorkshire
    628
    sounds like the turbo to me leaking oil into the exhaust and intake ,the produces clouds of white smoke , has the car lost power ?
    does it sounds as though the car is locking up when trying to start it ?
    Jul 2009
    37
    Quote Originally Posted by hollow View Post
    When you say locking up how do you mean?
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Think this may either be a turbo or oil problem
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Doesn't oil leak produce blue-ish smoke?
    VCDS USER
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Quote Originally Posted by SAiLO View Post
    True. Its unlikely to be turbo or oil problem.
    Take the car for a good 15-20 minute drive and get it warmed up, if theres white smoke it could be burning coolant, which means head gasket, or porous/cracked head usually.
    If it stops when its warmed up I wouldnt be too worried, diesels can be smokey until they warm up.
    Jul 2009
    37
    Quote Originally Posted by rickyquicky View Post
    It's only when you start it up, when its warm its fine just cold starts really x
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Quote Originally Posted by sarah1989 View Post
    That will be just steam . Nothing to worry about it will always do it when it's cold. When the engine and exhaust systems warm up all the condensation from the exhaust sysyem evaporates .
    VCDS USER
