Volks AutosAH Fabrications
Results 1 to 12 of 12
    Middlesbrough
    39
    Changing front indicator bulbs 2003 A3
    How easy is it to replace the indicator bulbs on the front lights? Had a look under the bonnet and there doesnt seem to be much room.
    Is it a headlight out job? Any advice or guide would be helpful.
    cheers
    c_w
    1,047
    I believe you have to drop the arch liner down and access from the wheel arch.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Yep it's wheelarch liner down (not a particularly hard job BTW) or very very skinny wrists.
    8P2 S3
    Oct 2008
    Telford
    2,484
    yeah done this, jack it up, turn the wheel in, remove the front edge of the wheel arch liner and you should be able to get in. Taking the wheel off gives you more room and seeing its your first time at changing them, i'd advise taking it off!
    B6 1.8T Avant s line gmbh
    Middlesbrough
    39
    cheers, will do it at the wk end then
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    I wouldn't bother taking the wheel off personally. I've had to get in behind there when taking my bumper off and I simply put full lock on.
    8P2 S3
    Oct 2008
    Telford
    2,484
    make sure you wearing some sleeves too, the wheel arch liner will rip your arms to ribbons if your just wearing a t shirt!
    Aug 2005
    London
    263
    I must have gypsy hands as I found it fairly easy to get my hands in and change the bulbs without going through the wheelarch liner method
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by davej_anderson View Post
    I think it depends on the engine also.
    8P2 S3
    c_w
    1,047
    Possibly depends on the headlights too as the connector for halogen lookis right in the way but for bi-xenon it's on the top so might not be as much of a problem?
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    I didnt bother removing arches, loosened headlamps and managed to get hand in! Few scratches though lol
    Middlesbrough
    39
    i have big hands lol
    ill take the arch liner out i think
