Monster MotorsportBadger5
Results 1 to 11 of 11
    aberdeenshire
    55
    possible boost issue?
    i currently have a standard 59 plate S3 and for the past few days o have been wandering whether i have a boost issue or whether it was simply me becoming used to the car?
    somedays the car seems to pull well through each gear however on some occasions and i have noticed it mainly in second gear at say around 20mph and accelerating it seems like there is a lack of boost and the car doesnt start to pull until at least 3200 - 3400rpm
    being new to the car i was unsure if i was imagining things or not so i thought i would ask the experts, im currently offshore but i intend checking the Diverter valve for any splits and getting the car vagcom'd once i return to dry land.
    any help or advice is appreciated
    cheers
    Callum
    aberdeenshire
    55
    bump
    Oct 2008
    888
    For a car your age, without doing anything to it yourself, take it to the dealers.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,815
    Ditto but how many miles are on the car? can't be that much if you are off shore regularly :S
    warren_S5's Avatar
    Oct 2007
    7,134
    Your car should have the new revision D boost gauge, so no rubbers to split in those.
    Boost control valve N75 could be at fault. May also be worth unplugging the MAF and seeing if it runs any differently.
    I'm not sure where the turbo's kick in on these cars; can't be much below 3,000rpm (anyone know?)
    Audi S5 3.0V6T Coupe Black Edition
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    2500rpm. i think you're getting used to the car.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    aberdeenshire
    55
    Quote Originally Posted by Boydie View Post
    im on a 2 on 3 off rota so the car is used quite frequently during the 3 weeks at home, milage is around 2.5k if i remember correctly
    aberdeenshire
    55
    @warren, thanks i will try these once i get home next week,
    @s. thats a possibility mate, if so then happy days but i would still like to investigate all posibilities just to make sure and put my mind at rest
    KRL
    KRL's Avatar
    Jul 2007
    523
    All you need to do to check if you have a boost leak is some logging with VCDS:
    1. Log block 115 for boost and check that Actual boost is meeting Requested boost throughout the rev range as below.
    2. Log block 114 for the N75 Duty Cycle (for N75 read wastegate) and check that after the turbo has spooled the N75 is not working too hard. Before the turbo spool the duty cycle should be at 100% as the wastegate is 100% open. After it spools it should remail at 40-60%. Any higher and it indicates a boost leak because your N75 is having to work to hard to maintain requested boost pressure. Here is what a healthy N75 cycle looks like:
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    aberdeenshire
    55
    thank you KRL ill get on to that when i return home and let you know! much appreciated
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    Ive got a 59 plate too & have posted up pretty much the same thread except mine has revo stage 1, evoms intake & forge dv. Did logs boost is fine so cant be dv so I think ive got used to it or the clutch might be slipping on mine
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
