Badger5AH Fabrications
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    MF Steering wheel
    I have a 2006 s-line which has the double din concert 6 disc headunit.
    I'm wanting to fit a MF steering wheel with the volume controls but have seen posts saying a new slip ring might be needed as well
    how do i know if i need to buy a new slip ring as well? is there any way of finding out without removing the old wheel first?
    cheers
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    scottie123's Avatar
    Oct 2008
    1,888
    Through vcds or ring your dealer, give them your reg and tell them you want the part number and price for the steering wheel ecu and slip ring that is on your car.
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    Thanks Scottie - i'm looking at a used wheel from a breakers without the slipring but i'm not sure whether to buy it if i need to buy a ring as well? does the wheel then need coding to the car?
    scottie123's Avatar
    Oct 2008
    1,888
    yes you will need to code with vcds
    aristides's Avatar
    Aug 2008
    Greece
    543
    Thats not always the truth about ringing dealers and hearing numbers :P
    It`s a weird thing what AUDI does with millions of different versions of the same product.
    Mine had a 1k0 ... ... AH ECU module that was compatible with cruise control but not multifunction but in etka , using my VIN, it said that i had the 8P0 (deluxe :P) version
    Just read it with VCDS it`s your best bet of finding the real part number! About the slipring you will have to pop the upper trim part behind the steering wheel, the sticker with the part number is on the top
    That`s what i did after every dealer messed me round with false numbers
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
