Volks AutosJMB Retrofits
Results 1 to 12 of 12
    Mar 2010
    11
    The VW R32 suspension is the same that in S3 2008 8P?
    The Vw R32 suspension is the same that in S3 2008 8P?
    For my surprise Audi is not selling the S3 in the USA. I must get my suspension before a track day and I am on a hurry.
    What other car have the same suspension? I want to buy some coilovers.
    thanks
    Mar 2010
    11
    Is the same suspension of the audi a3 2.0T quattro?
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    Let's start again...... what model have you actually got?
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Surely the R32 nearly 100kg heavier has different suspension to an S3? I could be wrong, just fancied a guess as i'm bored..
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Mar 2010
    11
    Audi S3 quattro 2008
    V6Pete's Avatar
    Feb 2009
    Northants
    1,492
    Quote Originally Posted by santi wrx View Post
    Ok. Struts are the same, but the S3 will use lighter front springs.
    S3-Dan's Avatar
    Quattro
    Mar 2009
    alnwick northumberland
    178
    but the point is they fit right ? theyl be a lttile stiffer but hes using it for a track day !
    Ibis S3 / GT3076R / 18" TD 1.3s Toyo R888's / H&R ARBs & Monotubes / USP LPFS / Turbosmart Eboost2 / WOT box / 500HP (EST)...and a TDI badge
    NY_Sportback's Avatar
    58
    Quote Originally Posted by S3-Dan View Post
    Definitely fit, I compare S-line springs to R32 off the car and they are the same height but the S-Line coil is a larger diameter (US spec R32 vs Euro Spec S-line)
    161
    Quote Originally Posted by NY_Sportback View Post
    Waddabout R32 vs Stateside Spec S-line? Are they going to be too low that I have to mind the sleeping policeman?
    V6Pete's Avatar
    Feb 2009
    Northants
    1,492
    Yes but springs are designed as sets. If the front is harder (and higher due to stiffness) than the rears, then it won't drive right.
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    That was kind of my point Pete, would make the car handle a bit odd and screw the handling up a treat wouldn't it?
    V6Pete's Avatar
    Feb 2009
    Northants
    1,492
    Quote Originally Posted by beanoir View Post
    Yeah it wouldn't be the best idea at all. The R32 / A3 3.2 has a considerably heavier engine, so will run different springs. He'd be better off buying regular 2.0T springs as these will be right for his weights.
