Monster MotorsportChris Nott
Results 1 to 9 of 9
    Mar 2010
    Bristol
    48
    I hope it aint serious!
    Hi to everyone here!
    I have just bought a 53 plate 2.0tdi sport and it's not going well already so hope to get some help!
    when i accelerate hard, the car becomes jerky... starts to accelerate, then stops and goes again, and when i was getting a feel for her on the motorway i couldn't get it over 3000rpm in either 5th or 6th gear which meant it wouldn't go over 105mph.
    it's been serviced regularly from new with audi, and was last done about 2k miles ago.
    i previously had a vauxhall astra which had a similar problem after the altenator was replaced and it was put down to the battery going dead flat, and as such, loads of errors showing upon the ecu, and once they were cleared ran smoothly again. the mechanic said the car had entered "limp home" mode and i was wondering if audis have something similar or i have a more sinister problem??
    sorry if something similar has been posted before, but couldn't find anything like this.
    thanks in advance for your help!
    Tyler Owen's Avatar
    Dec 2008
    Cirencester
    78
    Throttle body or EGR Valve would be my guess, but that said i'd have thought that would have illuminated the EML
    Mar 2010
    Bristol
    48
    thanks for the quick response!!
    yeah on the astra a warning light came on and it wouldn't accelerate at all, where as on my a3 it was ok (apart from the jerking) up to 105, and no warning lights
    26,716
    Welcome to the site.
    Fuel pump under rear seat, a fuel supply issue, maf, multitiude of things could be, would be good to get someone with vagcom near you to scan it for any codes thrown 1st, link in my sig has users in areas willing to do for beer tokens.
    Mar 2010
    Bristol
    48
    thanks for that, a great help
    what's "maf"?
    26,716
    Mass Air Flow sensor
    Oct 2009
    111
    Don't worry about not being able to achieve more than 105mph - that's the sort of speed that loses you your licence!
    Mar 2010
    Bristol
    48
    i agree, and normally i wouldn't go that fast... but you have to try your new car!!
    Mar 2010
    Bristol
    48
    just an upate as had my car fixed and hope this may help someone in the future with similar problems!!
    had the fuel filter and maf changed and all's well again
    well apart from the shaking when in netural or idle. reading someones post today someone said possible flywheel and or clutch problems.
    cheers for the help anyway guys...
