EM TuningJMB Retrofits
Results 1 to 7 of 7
    Aug 2008
    Manchester
    130
    Removing trim around the gear stick and from the ash tray - how?
    Managed to change all of the door trims easily but am a little stuck on gear stick trim and don't want to damage it. Same goes for the ashtray - any tips? I'm replacing the wood trim for piano black.
    cheers!
    Fossie
    Rhubarb Triangle
    3,969
    Remove receptacle part of ashtraythen hook fingers under front of trim and give it a firm tug upwards. The trim is only held on with clips and easily comes off - and what's more important easily goes back !!
    scottie123's Avatar
    Oct 2008
    1,888
    Just close your eyes and pull the trim.
    As said , it will pull off.
    ste
    reverse gear
    west midlands
    121
    lol i like the way you put it
    ste
    reverse gear
    west midlands
    121
    lol i like the way you put it scottie
    Aug 2008
    Manchester
    130
    Cheers, i'll have another go later. Got the gear lever surround off but couldn't quite see how it comes off and didn't want to risk breaking any of the clips.
    Ta!
    Aug 2009
    33
    I came across this same problem a little while ago... I wrote a how to with pictures that explains what you're trying to do... hope it helps! :D
    http://www.audi-sport.net/vb/showthr...w-to-DIY-Guide
