EM TuningAH Fabrications
    NY_Sportback's Avatar
    58
    Need Long Coding for 2009 Facelift Sportback Tail Lites
    I installed Euro spec tails on my US Sportback and the blinker and brake light both come on during braking and when signaling a turn, need long coding so I can get the brake lights to come on only during braking and turn signal only when turning, Thanks in advance
    May 2009
    lincs
    73
    Byte 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - fog lamp as a taillight
    Byte 12 to Dec = 36 - dimming rear stand light
    Byte 19 Bit to cold diagnosis rear active - this must be activate
    here are a couple of links which I used to install mine
    http://forums.fourtitude.com/zerothread?id=4074059
    http://forums.vwvortex.com/zerothread?id=4027491
    post some pics when you have done them
    2005 Brilliant Black A3 Sportback S-Line 2.0TFSI Panaramic Sunroof, Bose, RSNE, Heated Front Seats, Rear Parking Sensor
    Mods so far: Armrest, RS Oilcap, FBMFSW, Facelift Tail lights, S3 Pedals, Black Grille & Surround, Eibach Pro Springs, S3 Front Brakes, Goodridge Lines, Black Edition RS4 alloys, Maxogen ITG Induction, Bi-xenons, Revo Stage 2
    Apr 2009
    Florida (previously Liverpool)
    655
    Looks from teh SECOND post that there's some re-wiring required, beyond simple VAG-COM programming.
    in that post, he's not using the Kufatec pre-made harnesses, he's made his own.
    I'd be interested in knowing exactly how it's wired.
    NY Sportback, -forgive the silly question, but you do know that the rear harnesses are side-specific, -right? -I wondered if cross-swapping your harnesses over might cause such a problem...?
    Keith
    58
    Quote Originally Posted by VWAddict View Post
    Keith
    My car is a 2009 so the lights are direct plug in, I need long coding for a 2009 Euro Spec sportback so I can get mine working correctly
