Results 1 to 14 of 14
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    going to look at a 2004 tdi
    tomorrow. any naughtys i should no about. i have tryed the search and nish comes up.
    thanks..
    also can cruise control be retro fitted like on the 8l`s?
    thanks
    Now to many mods to list! Lots of power, torque and Leather!
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,919
    Check Service History, Obviously HPI it!, See if its ever had a replacement Cylinder Head, you need to check the engine code. Audi had a bad batch between 2004 -2005. Make sure clutch isnt slipping esp if its been mapped. Good luck, hope its a good one.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    why the cylinder head.... are these a problem on these then? should it of been changed?
    Sarah's A3's Avatar
    5,919
    Between 2004 -2005 Audi had a batch of heads that had a manufacturing problem causing them to be porous. The way I found out on mine was that the coolant level kept dropping. Basically, looses coolant under pressure etc. Lots had them changed under warranty, some, like mine, were out of warranty and the cost is around 2k. You may be ok, I was just unlucky, so thought i'd mention it.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    ahh ok wkd... thanks for that.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,364
    Thats only on the 2.0 litre CR TDis isn't it?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Sarah's A3's Avatar
    5,919
    Quote Originally Posted by ALPINE View Post
    Looks good to be honest! Has a warranty so peace of mind! only 2 owners too. Doesnt mention about service history but does say the cambelts been done. Just make sure the service books been stamped! And HPI it!!!
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    thanks..
    thanks
    As mentioned cylinder heads on early BKD engine gave problems which is the main thing to check. Then just the usual clutch and turbo stuff really.
    03G 103 308 A years 2003 to 2005.55 allmost all cracked
    03G 103 308 B years 2005.5 to 2006.6 only a few cracked
    03G 103 308 C years 2006.5 to 2007.5 none cracked cracked
    Quote Originally Posted by Byzan A4 View Post
    No. The problem was sorted by the time VAG switched to the PD170 and common rail engines.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Sarah's A3's Avatar
    5,919
    yup only 140's
    Oct 2008
    Telford
    2,485
    Quote Originally Posted by devonmikeyboy View Post
    [B]03G 103 308 A years 2003 to 2005.55 allmost all cracked.
    Although your right, its worth pointing out that most of them were fixed under warranty so you would be unlucky to find one after 5 years still suffering. I would only buy an early one with a full audi history, that way you can check if it was done :-)
    B6 1.8T Avant s line gmbh
    Sarah's A3's Avatar
    5,919
    Quote Originally Posted by Lee_R View Post
    I bought mine that had full history etc and over 100k miles and after I bought, its head went! Was out of warranty too. So yeh some of us are unlucky! At the time I didnt realise there were issues!
    Feb 2007
    1,257
    I think the only "issues" is the way you kill sorry i mean drive your car Sarah.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    sometimes worthwhile checking out previous mots to see for yourself if advisorys have been followed up on or if it has failed for anything
    http://www.motinfo.gov.uk/internet/j...us-Request.jsp
