Sky InsuranceAH Fabrications
Results 1 to 11 of 11
Thread: rad leaking
    tdi-man's Avatar
    Jul 2009
    1,612
    rad leaking
    had a water leak for a few weeks had a quick look tonite leaks coming from drivers side of the rad is there any think else to look at down there or is it a new rad job ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    New rad
    I had mine replaced last week as it was leaking at the bottom corner (corrosion), this is a common problem on the mk5 Golfs as well, main dealers changed mine after diagnosis and total was 495
    Get yourself a rad from GSF, ECP, etc and get an indy to fit it if you can't - dealer charged me 105 p/h labour
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    tdi-man's Avatar
    Jul 2009
    1,612
    yup ok im on the case rads about 80.00 and i'll pop down m8s garage tomo to check it for me first.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by robby View Post
    New rad
    Why the hell did you go to a dealer for if he charges 105 per hour ?
    As to the water leak it might be something as simple as a loose pipe connector without looking it could be lots of things. If it is the rad and it`s a small leak you might want to try some Rad Weld or simular product as it`s only about 2.50-5 a bottle as you have nothing to loose by trying.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    Quote Originally Posted by devonmikeyboy View Post
    Warranty
    Feb 2007
    1,257
    Warranty
    Well you didn`t get charged then really did you if it was done under warrenty.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Had mine changed under warranty due to a leak.
    Did think that it was the dreaded BKD head issue, but turned out to be the rad leaking.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    May 2009
    West Yorkshire
    1,628
    Mines in this Saturday morning for a rad leak, replacing the rad with a new genuine Audi one.. Only the suspension bushes and bottom arm bushes to do and then mechanically it's mint, oh and put my new glow plug in!
    Face lift time after that!
    Audi A3 2.0L TDI S-Line Sportback
    May 2009
    West Yorkshire
    1,628
    Quote Originally Posted by Gti Jazz Blue View Post
    Paul
    Have you got any photos of your motor, just noticed your profile photo, looks like an 8P1 like mine.. would like to see the chrome (assuming) S3 mirrors.
    Feb 2007
    Hampshire
    1,654
    They are the plastic version so only a replacement cap that James (MarriedBlonde) fitted - more pics here http://www.audi-sport.net/vb/members/gti-jazz-blue/albums/my-a3/
    With the number of genuine S3 ones that are being nicked, I am seriously considering putting the black ones back on.
    That or a sticker that says "Oi thicko these ones are only plastic so not worth anything on Ebay" - LOL
    Paul
    VCDS HEX-USB+CAN
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    Well i've had to pay myself and send the invoices for AA and selling garage to reimberse me - so technically i was charged
