AH FabricationsVolks Autos
Results 1 to 15 of 15
    222
    OIL CHANGE FROM AN INDEPENDENT DEALER !
    Hi , i've read that many of you have the oil change done at an independent garage whilst still having the regular services done at an Audi dealer . My question is - does this in any way invalidate the Audi warranty , thanks .
    waqi's Avatar
    Apr 2009
    Yorkshire
    150
    As long as genuine parts are used and receipt is kept, and the garage is VAT registered your warranty should be fine
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    use geniune recommended oil and parts but dont tell them!
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    I think you will find very few people on here go to a dealer to get the car serviced as it can usually get done cheaper and have better service from an independent. To answer you question you never need to take your car to a Audi dealer to get it serviced as long as the garage you take the car to uses OEM standard Audi parts. The days of having to take a car to a dealer to keep it`s warranty finished many years ago.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Sarah's A3's Avatar
    5,923
    Quote Originally Posted by devonmikeyboy View Post
    Is that right? I'd still be worried if ever a problem occured and you wanted to go down the warranty route! But if you are right, happy days! I use an awsome indi!!!!
    c_w
    1,061
    Most Audi dealers do oil / filter service for 99 which isn't too bad considering the oil is probably best part of 50 plus an oil filter plus you get the dealer stamp.
    Oct 2008
    888
    Quote Originally Posted by c_w View Post
    Kwik fit 50, OEM parts and same oil.
    markwiggy's Avatar
    Third Gear
    Oct 2006
    North West
    1,123
    Providing a genuine Audi oil filter was used, Audi would not know the oil had been changed, so don't worry.
    Mark
    07 S3 Sprint Blue Now Sold
    12 Range Rover Evoque Dynamic Now sold
    A3 20 TDI S-Line Sportback in Daytona Grey with Aluminium Roof Rails, Fine Nappa Leather, Sat Nav, Comfort pack,Audi Sound System, Folding Mirrors, Heated Seats, Privacy Glass, Interior Light Pack, Non Smoke Pack.
    964kevin's Avatar
    98
    European block exemption is the ruling which made all of this legal, use genuine parts and you should be ok.
    kevin
    222
    Thanks guy's , i was a little concerned that if you had the oil changed independently and something needed work under warranty that was engine related they may be able to refuse . Do you get a stamp for oil change or is it just for the main services ? Thanks .
    c_w
    1,061
    Quote Originally Posted by dc240969 View Post
    Just my opinion, but I would never take my car to Kwikfit for an oil change even if it was 20!! I would also query if they use the exact same oil since they generally buy in bulk barrels of generic oil and have to serve all manufacturers and grades, it's probably a similar/same viscocity but I doubt it'd be the same brand and type exactly that Audi would use.
    Oct 2008
    888
    Have you tried Kwik Fit at all? l would say other wise.
    V6Pete's Avatar
    Now running on Bentley's y'all
    Feb 2009
    Northants
    1,492
    I disagree. I think an awful lot of people on here use main dealers! With a car under warranty, or recently out of warranty, it's false economy to use an independent. Audi have quite competitive servicing rates for cars over 3 years old, and the main dealer stamps do add value to resale. You have no chance of any Audi goodwill if it's not been serviced by main dealers, and this can be worth 1000's down the road if you have any problems.
    Unless a car was many years out of warranty, and was obscenely expensive for main dealer servicing, I would always stick with main dealers. Not because I think they do a better job, but sadly most people do.
    A3 3.2 V6 S-Line | Brilliant Black | Full Votex Kit | 18" Cades Bern / 19" Bentley 5 Spokes in flat grey with 215/35 Falkens | Custom Code Remap
    V-Maxx coilovers | Remus exhaust | Pipercross Viper | Goodridge Brake Lines | RNS-E | Bluetooth | FBMFSW
    Previous VAGs: 99 S4 Biturbo | 06 Golf GT TDI | 08 A4 S-Line TDI PD140 | 02 Passat 4.0 W8
    Other toy: Suzuki GSX-R750 K3 Black/Silver
    Leather arm rest for sale | S3 mirror covers for sale | 09 3dr tail lights wanted | Twin grills wanted PM me!
    c_w
    1,061
    Of course I haven't
    With regards the oil, I just can't see them having the huge range of oils that each dealer/make would have for their cars. Not only the right grades (0/30, 0/40, 5/30, 5/40, 10/40, 15/50, 10/60 etc) but the brand that may be recommended/used at a dealer, sometimes as part of a long life service schedule perhaps.
    For example, could I roll in to Kwikfit with my BMW M Coupe and get an oil change for 50 using the engine-specific Castrol TWS 10/60 for M Series engines? No is probably the answer! and they've probably never heard of that oil either.
    Now I don't normally use dealers but my A3 is a low mileage 56-plate so for 99 it seems logical to keep it full Audi services. But even if it was an older car/more mileage/not bothered about full dealer history, I might consider the 99 service at Audi. Otherwise I would use an indepedent specialist (who probably won't be much cheaper at that price) or do it myself.
    Oct 2008
    888
    Well l got what l asked for.
