JMB RetrofitsAH Fabrications
    Rabbit222's Avatar
    Jul 2007
    South Africa
    669
    KMD vs Autotech HPFP
    Hi guys,
    Not sure if this has been discussed here before so I thought I'd ask the question...
    How do these pumps compare in terms of longevity? I have had a first revision KMD which failed in my ex S3 and that made me a bit skeptical about the product. We have been getting quite a bit of queries for HPFPs and the KMD is definitely the cheaper option....
    All opinions welcomed and no I'm not interested in APR.
    Shaun
    2012 RS3 / Daytona Grey / Alu pack / revo3+ / LOBA500P / LOBA CNC Intake pipe / LOBA HPFP / Forge Race FMIC / Milltek resonated exhaust / revo intake system / Devils own WMI / 20" BBS CH-R Titanium / H&R Monotube coilovers / H&R Anti Roll bars / Alu Roof rails / Hybrid RS grille / R8 paddle shifters /
    david_phillips95's Avatar
    Nov 2008
    538
    Im running the Autotech pump and have no complaints, after doing some logs with VCDS on the fuel rail pressure i have seen that the Autotech pump is perfroming perfectly. The specified pressure has been as high as 133bar and the pump is able to meet this demand. The speicified pressure and actual pressure follow eachother nicely now.
    I purchased my autotech internals for around 240.00 from a groupbuy on the forum for mk5golfgti.co.uk. I stripped and rebuilt my pump with the new internals, its really simple if you follow instructions and take your time.
    Heres the thread - http://www.audi-sport.net/vb/showthr...ht=#post893228
    Cheers Davie
    *ace*'s Avatar
    Dec 2009
    29
    Will be interesting to know how the newer revision holds up then.
    *topic subscribed
    May 2009
    47
    Quote Originally Posted by *ace* View Post
    *topic subscribed
    Does someone know if the facelift s3 OEM fuel pump would provide enough pressure for a stage 2+?
    *ace*'s Avatar
    Dec 2009
    29
    As i understand it, nopes bud.
    Revo2+ still requires it
    Feb 2009
    60
    Yup, a KMD, APR or autotech pump/kit is required
