AH FabricationsVolks Autos
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    220
    Changing steering wheel to multiple-function type
    Hi.
    My S-line 3-spoke steering wheel is without the multiple-function.
    I cruse Controll so I hope I do not need to change the slip ring
    My question is. Can I use a steering wheel from
    a A4? Any changes in diameter?
    There is some cheap ones on eBay.
    Thanks again for helping
    scottie123's Avatar
    Oct 2008
    1,888
    Should be fine. I fitted a a4 s line one to mine before I got a fbmfsw
    05 SB SE BKD
    Build Thread
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    The A4 wheel is exactly the same as your a3 one so its a straight swap. BUT the airbags are different on some a4 steering wheels so check first...
    Stampie's Avatar
    Fareham, Hants.
    105
    Would a non multi function car need to be Vagcom'ed before the multi function wheel would work?
    2010 - Monza Silver - A5 3.0tdi Quattro S-Line Special Edition.
    scottie123's Avatar
    Oct 2008
    1,888
    yes. coding will be needed
    05 SB SE BKD
    Build Thread
    Jul 2009
    Norway
    220
    Ok so the steering wheel is the same.
    To be safe I use my original airbag, is that ok?
    The one I found is without airbag.
    Some one hear got a MFSW for sale?
