JMB RetrofitsBadger5
Results 1 to 7 of 7
    Aug 2004
    An der sud Koste
    711
    Getting into the rear!
    Whilst test driving a 3 door, the only way I could find of getting into the rear seats was to pull the lever up near the seat top to tilt the seat back and then bend over and pull the seat forward on its runners so there was enough room to get in. Is this right??? Can't you do it all in one movement like in many 3 door cars, i.e. back tilts and seat moves forards in one go? Is it really a 2 stage process?
    Feb 2004
    Clearfield, PA
    892
    Re: Getting into the rear!
    yeah sorry afraid so mr!
    Aug 2004
    An der sud Koste
    711
    Thanks mate. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Shame, reminds me of my first ever car in the 80's, a Metro!
    Surely they could've moved on since then! The brochure says 'easy entry seats' - I was hoping that meant they would tilt and slide or similar in one movement!
    Oct 2004
    belfast
    17
    some cars this only happens on the drivers side is the a3 the same
    imported_Adambsmith
    My Civic Type R is annoying like this. On the passenger side, the front seat tilts and slides forward in one go but then returns to the same position all the time - very upright - passengers are always adjusting that seat.
    The driver's side is the same as the A3 - two motions needed for people to access the back - I just send back seat passengers around the other side [img]/ubbthreads/images/graemlins/devil.gif[/img]
    Jun 2003
    World of my own
    9,813
    The old A3 tilts and slides forward, can't believe they've taken a step backwards.
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    yep one hand and one movement for both seats on mine
    what I think is bad design though is to lift the lever to slide them backwards as you should push and not pull the lever
