AH FabricationsJMB Retrofits
    scottie123's Avatar
    Oct 2008
    1,888
    suitable ground point for electrical instal
    I am retro fitting some front fogs to my car.
    I have the kufatec loom, and the instructions are follows
    Please disconnect the battery before starting installation.
    Please wire the loom starting from the fog lights to the following connections:
    Wire configuration:
    Gray - control unit for central electric connector D PIN 2
    Gray/ Yellow - control unit for central electric connector A PIN 4
    Brown - Ground point - Battery
    Single loom - Light switch 10-pole connector – PIN 5 --- to the control unit
    for central electric 16-pole connector E PIN 6
    Connectors are marked directly on the control unit for central electric.
    Looms need to be wired through the rubber beak underneath the battery. Therefore the battery needs
    to be removed as well as the carrier below.
    After installation you need to code the control unit for central electric to fog lights.
    Would some one be able to clarify what is the ground point?
    Is it the negative on the battery connection, or is it ok to just connect to a metal part of the chassis as a ground?
    Sorry, but my electrical skills are lacking a fair bit
    05 SB SE BKD
    Build Thread
    Khufu's Avatar
    West coast of Scotland
    5,693
    Its a grounding point on the body, i've seen people using the bolt at the fusebox when doing the coming home mod but there's a proper one below the fusebox/central electronics module at the inner arch. If you remove the trim where the bonnet catch is you will see it. It has brown wires going into it.
    scottie123's Avatar
    Oct 2008
    1,888
    Thanks khufu!
    I thought that was the case,just wanted to check.
    Bring on the morning
    05 SB SE BKD
    Build Thread
