EM TuningJMB Retrofits
Results 1 to 12 of 12
    L80EWY's Avatar
    Sep 2009
    331
    Can anyone tell me what this part is called..
    The part ive pointed out with the arrow, iv bent it
    L80EWY's Avatar
    Sep 2009
    331
    Anyone ?
    Khufu's Avatar
    West coast of Scotland
    5,693
    The long arm? looks like your trailing arm your talking about.
    How'd you manage you bend it?
    L80EWY's Avatar
    Sep 2009
    331
    I reversed into a kerb at speed unfortunatly and its pushed my wheel to the front of the arch
    Oct 2008
    Telford
    2,488
    yeah its the lower arm (the big bit) should be able to get one from a breaker easy enough.
    B6 1.8T Avant s line gmbh
    L80EWY's Avatar
    Sep 2009
    331
    Thanks lads
    L80EWY's Avatar
    Sep 2009
    331
    Could anyone tell me if this would fit?
    http://cgi.ebay.co.uk/Audi-A3-2008-C...item3a4c4b736a
    Khufu's Avatar
    5,693
    part numbers seem the same between A3 & convertable so I'd say yes.
    L80EWY's Avatar
    Sep 2009
    331
    Thank you, anyone confirm this?
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Yeah same part, will fit your car
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    971
    I would also check the other suspension arms, my brother hit a kerb in my a3. Have a close look at the lower suspension arm ( the one the spring sits in) this arm has section in which is ment to buckle with the result if impact
    Previous
    S
    Ibis White - 2007
    Current
    A5 Ibis White - 2007
    S3 Black - 2001
    VCDS user
    L80EWY's Avatar
    Sep 2009
    331
    thanks that bit seems to be fine just looks like the trailing arm thats bent
