Results 1 to 15 of 15
    Dec 2008
    249
    kufatec xenon autoleveling instructions
    I'd appreciate it if someone on here who bought the autoleveling kit / loom of kufatec and got the instructions could email them to me? I've had a look at the wiring diags in elsawin but want to clarify a few links and believe the instructions provided by kufatec wuold help. thanks in advance.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    http://audiforum.us/8p-platform/1344...incorrect.html
    theyre possibly even wired incorrectly
    Dec 2008
    249
    Thanks mate, that post it very useful
    Dec 2008
    249
    Im trying to make sense of the wiring diags for the bi-xenon as thinking of making my own looms after reading that thread bout kufatec's. I've managed to get the pins outs for the 2 sensors to the autolevel module (J431) which is on 153/4, however struggling to find the pin outs for the other 11 cables coming out of J431. Any help would be appreciated.
    Dec 2008
    249
    This is the diagram im going off by the way:
    I have bi-xenon (not adaptive) so am asuming its xenon-plus in elsawin.
    Khufu's Avatar
    West coast of Scotland
    5,693
    clicking on the number in the square box takes you to where its linked to.
    Dec 2008
    249
    Quote Originally Posted by Khufu View Post
    I thought they were there for a reason, however clicking on them doesnt seem to take me anywhere
    Khufu's Avatar
    5,693
    mmm, it should do - i tried 117 & it took me to where it goes to the level motors.
    Dec 2008
    249
    hmm, when I hover on the numbers they become enlarged and blue with a cream box round them but nothing happens when I click
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    sounds like a plugin problem with your pc, what does the elsawin window look like?, is it almost like an internet browser id expect teh first port of calls for a fix on that should be a java update or a macromedia flash update
    26,720
    All the boxes denote is which number at the bottom of a page they goto, you will see its numbered across the bottom of each page, so if the box says 86, scroll up/down to where the number 86 is & then follow the line upwards to the point the wire ends up at.
    Dec 2008
    249
    Quote Originally Posted by P5SND View Post
    It looks like an IE window yes, will update java and flash and see what happens, cheers mate.
    Dec 2008
    249
    Cheers Nige, that will do as a workaround for now.
    Dec 2008
    249
    Can someone advise where pins 2 & 3 from connector 26a go plz. It says CAN high & low but not sure exactly where that is. Also going to be using 24 awg 0.2 amps wire for all the wiring, will this be ok?
    26,720
    Well they would either go back to the gateway module or just connect onto the nearest module that uses the same bus, if you follow those pins anyway it will show/tell you where it goes to.
    Bus wires use very low power as such, so should be fine, I've used speaker wires for few things, worked fine & no errors to date, just didnt wanna chuck the wire away.
