EM TuningChris Nott
Results 1 to 7 of 7
    Pii
    Pii's Avatar
    London
    748
    Front Passenger Seat Stuck
    Need some help guys.
    Whilst my friend was trying to get into the back of the car he somehow managed to cause the seat to become stuck. As a result, the seats can not longer be adjusted forward or backwards.
    The lever can still be pulled up but is missing that clicking/locking noise so the seats wont shift.
    Any ideas?
    Pii
    Dec 2009
    155
    Not sure exactly in ure case mate but I couldn't move my seats forward to let people in the back unless I pulled up the handle. Audi fixed it under warranty so don't know exactly what the problem was.
    Pii
    Pii's Avatar
    London
    748
    Re: Front Passenger Seat Stuck
    Yeah I was hoping to avoid going that route unless it was a last resort.
    Bummer!
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Mine did that once! The front seat needs to move the full cycle of its action to stop it getting jambed, which is what you have there mate.
    When you pull up the leaver the seat back folds forward and then you slide the whole seat forward until it stops.
    To put back lift up the handle and slide the whole seat base back THEN lift up the seat back into position.
    If the seat dosent go forward all the way when you 1st move it forward it will lock in the wrong position. You need to get it to go forward to unlock it mate.
    ie, seat back folded forward and slide the base towards the dash. Once it completes this action it will work as normal again but you need to slide the base backwards and forwards only when the seat back is folded forward else it locks up as you have just discovered.
    Hope this helps mate as it wound me up for a while too!!!
    Gaz
    chris1988brown's Avatar
    middlesbrough
    578
    gaz has got the nail on the head, however if this still doesnt fit it the cable wil have come off it bracket there for not allowing the catch to release poperly, if you look under the seat you will see the release cable and just clip it back into its securing bracket.
    hope this helps
    chris
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Pii
    Pii's Avatar
    London
    748
    I have lifted the top lever and and then lifted the bottom lever but the seat still won't budge! Have I not done this right?
    Couldn't see under the seat as the storage compartment is blocking the view or maybe I dunno what I should be looking for.
    Trying to avoid having to go to Audi as I won't be able to do this until 2 weeks time.
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    lift the top lever push the seat back down as far as it goes the steering wheel may be in the way but push it down all the way then slide it all forward towards the dash!
    then it will slide backwards on its own just about.
    gaz
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
