Position of securing clips
1 - Luggage compartment side trim
2 - Spring clips (4x)
q Left-side; with luggage compartment light
q Right-side; with socket: Removing and installing → Rep. Gr.96
Removing
– Remove rear seat bench → Chapter.
– Fold rear seat backrest forwards.
– Disengage securing cords from rear lid retainer and pull rear shelf to rear, out of mountings on side trim of luggage compartment.
– Remove luggage compartment floor covering.
– Remove rear cross panel trim: vehicles with front-wheel drive → Chapter; vehicles with four-wheel drive → Chapter.
– Unclip luggage compartment side trim -1-.
Trim (left-side):
– Unplug connector at luggage compartment light -4-.
Trim (right-side)
– If vehicle is fitted with socket, unplug electrical connector at luggage compartment socket.
All models:
– Take out luggage compartment side trim -1- to front.
Installing
Installation is carried out in the reverse order, note the following:
Note
Renew spring clips -2- if damaged.
– Note position of securing clips → Fig..
– Before fitting luggage compartment side trim -1-, make sure spring clips -2- have been positioned correctly.
– After completing installation work, fit seal for rear lid -5- over luggage compartment side trim -1-.
2 - Spring clip
q Qty. 4
q Renew if damaged
3 - Flap
q Only on vehicles with navigation system with CD drive control unit -J401-
4 - Luggage compartment light
q Only fitted on left side
q Removing and installing → Rep. Gr.96
5 - Seal for rear lid
6 - Nut, 2 Nm
q Qty. 3
7 - Retainer for luggage compartment side trim
q Removing and installing → Chapter
