JMB RetrofitsAH Fabrications
    Unhappy Diverter valve, sorry
    im sorry if this has been spoke about 100 times, but i was wondering if any one had any advice on me buying a new diverter valve, i was thinking forge, what are the gains in sound, and performance if any??
    thanks
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Quote Originally Posted by kevbev View Post
    thanks
    Yes it has been asked about a hundred times or more,but for the record.....
    Forge's valve is about the best aftermarket one,but if you're buying one for sound,forget it,as this isn't what it's aimed at.
    You can buy an atmospheric spacer for it,which will bleed a little air and make a hissing sound for you,but the purpose of the uprated DV is to allow you to run higher levels of boost without the OEM valve problem of leaks at higher pressures.
