Chris NottVolks Autos
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Loss of power under load, blue smoke, VCDS codes.
    Hi guys,
    recently my car has developed a problem - when under load (for instance: on 4th gear reaching 3k revs and pushing the accelerator pedal) the engine will noticeably lose power, then car goes into limp mode.
    A few weeks ago I've noticed car being really smoky, so I took off the bluefin remap and carried on without it. Blue smoke would still be visible when starting from the traffic lights etc.
    Think it might be the turbo saying goodbye, but I've also been thinking about boost pipes since I can hear hissing sound when I take my foot off the accelerator when on boost.
    Here are the VCDS codes.
    Can someone experienced recommend a good garage to change the turbo and if I have to the pipes as well in London area? East London preferably.
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC 0000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D4FNJ07O
    Coding: 0000032
    Shop #: WSC 66565 257 00032
    2 Faults Found:
    18041 - Accelerator Position Sensor 2 (G185): Signal too Low
    P1633 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.46 V
    Bin. Bits: 00000111
    Torque: 0.0 Nm
    Bin. Bits: 0 01 0
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - -
    Freeze Frame:
    RPM: 3276 /min
    Torque: 326.0 Nm
    Speed: 113.0 km/h
    Load: 89.4 %
    Voltage: 14.44 V
    Bin. Bits: 11000000
    Absolute Pres.: 2233.8 mbar
    Absolute Pres.: 2590.8 mbar
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    VCDS USER
    May 2009
    West Yorkshire
    1,628
    Turbo is on it's way out, most probably the bearings in the turbo and that's why you are seeing blue smoke out of the back, i have just had turbo failure and i lost ALL the oil, so if yours goes pop turn the engine of straight away! Otherwise it's new engine time.
    Audi A3 2.0L TDI S-Line Sportback
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Looking at those codes i wouldnt say the turbo is knackered but something else especially as its bringing up a boost pressure reg fault,normally when turbo's are going there is no fault codes,normally a turbo on its way out produces grey smoke,blue smoke is normally burning oil or internal engine component damage
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I'm taking it to a garage on monday. Hopefully it's just a boost leak from the pipes. Let's see what they say. Booked it with audi for Tuesday but might go independent on Monday to check what they've got to say. Thank God the warranty covers turbo....
    VCDS USER
