JMB RetrofitsBadger5
    clem2192's Avatar
    Sutton, Surrey
    173
    Electric Window Issues
    Guys / Gals,
    Having issues with my passenger window recently. (2004 A3 3.2)
    Basically when opening or closing the window it seems to be very slow and noisy (its more noisy when closing), it also struggles to close the last few inches.
    Also when the passenger window is partially open and you attempt to close it then it it opens more and you have to hit the switch again before it'll go up.
    I have considered the switch but it happens with both driver and passenger switch.
    I am guessing its either the window regulator or the motor as this is a common problem with the VAG range.
    Anyone else experienced this problem and had it resolved?
    Ryan
    MG
    Aug 2009
    137
    I don;t know the answer, but my A3 is doing something similar with the drivers window occasionally - it goes up to the top when closing then instead of staying shut it comes back down again. I'm assuming it's the regulator??
    _________________________
    2005 A3 2.0T S-Line Quattro, Phantom Black, Superchips remap, H&R 35MM Springs, S3 brake upgrade, lamin-x, full MV exhaust, 19" anthracite Sportec Mono 10s.
    Dec 2006
    Southampton, UK
    29
    MG, mine did the same thing! Not sure what the problem was, traded it in a few weeks ago for another model. It seems to be common fault though.......
    ghouseman's Avatar
    Gazza
    harrogate
    92
    keep your finger on the button for a few seconds when the window is at the top, and it should reset itself
    clem2192's Avatar
    Sutton, Surrey
    173
    ghouseman,
    will this rectify the slow and noisy winding problem too?
    when you say on the button, do you mean keep it in the close position for a few seconds when fully closed?
    Ryan
    clem2192's Avatar
    Sutton, Surrey
    173
    Also can anyone please give me the part number for both the passenger side window motor and regulator?
    (2003 3.2 V6 3dr)
    Cheers!!
    Ryan
