AH FabricationsChris Nott
Results 1 to 11 of 11
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Camber adjustment
    Fitting my Weitec Hicon GT's soon, might want a slight bit of camber on the rear wheels
    I'm 99% sure the Weitecs dont have camber adjustment, so how do i go about this? Just camber shims?
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    You cannot adjust the camber on the A3's so you would have to use shims IMO but personally, I wouldn't - you will go through tyres! 19" tyres are not cheap!
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Very true Boydie, but camber is worth it :P
    I'll be back!!!
    Oct 2003
    up north...
    767
    the rear camber on the 8p is factory adjustable - there is an eccentric bolt arrangement - the factory settings is 1.5deg negative camber,
    thats probably a bit too much really - if you reduce it the top of the wheel moves out to fill the arch more.
    its the front end that doesnt have any camber adjustment unless you fit the fwd tt bottom arms and ball joints, then you get between 1.5 and 2.5 negative camber approx
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    So what do i need to adjust at the back dunk?
    I'll be back!!!
    scottie123's Avatar
    Oct 2008
    1,888
    Smudge, I got mine done at a STS tyre pro garage. They had the full laser alignment kit for tracking,camber etc.
    They adjusted the rear for me. I'm sure it was about 30.
    Get your ass to a garage and let them worry about how to adjust the rear
    As stated previous, only the rear is adjustable. They tweaked mine by 0.5 degrees
    05 SB SE BKD
    Build Thread
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Sweet cheers Scott
    I'll be back!!!
    Oct 2003
    up north...
    767
    the just unlock the lockiing bolt and rotate the adjusting bolt when its attached to the alignment machine - there is one for camber and one for toe
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
    May 2010
    Hej,
    Most excellent, is there any chance to could put up some pictures with the eccentric bolts that should be adjusted.
    Thanks/Stuart
    Quote Originally Posted by dunk View Post
    May 2010
    Can you make these bolts
    If i put up a picture can you mark these adjusting bolts, I have a 2007 sportback and the wheels seem to be all over the place. My local garage said this (camber and toe) couldn't be adjusted on a front wheel drive car.
    May 2010
    http://etka.auto2.ru/epc/cat/au/A3/2005/412/53/4153944/
    Position 9 and 10 are the adjustment bolts/washers
