Results 1 to 11 of 11
    Aug 2009
    33
    Question Whining Noise from back of car
    Hi,
    I've noticed a weird whining noise on my 2007 S3. It only happens when travelling along between 55-60mph and is coming from the back of the car.
    I recently swapped the wheels round from front to back, that had no effect.
    Just wondering if anybody has any idea what this might be?
    Thanks Bezza
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Are you still getting it with the front wheels now on the back?
    Have you hit any big pot holes recently?
    Could be a wheel bearing but I had something similar in my TDI and had priced up 2 new wheel bearings for the rear of the car - turned out it was the tyres!! They were warpped and caused the car to whine under acceleration and constant speeds.
    Aug 2009
    33
    Quote Originally Posted by Boydie View Post
    Yes
    Who hasn't! The roads are like swiss cheese at the moment! Saying that, I'm always very careful, as far as I'm aware I've not done any damage.
    I also thought it might be tyre related, I've had that before on a previous car. However moving the tyres round on the car made no difference. So I'm thinking it's something not related to the alloy or tyre.
    I also only get it when at a steady speed between 55-60mph. Never hear it when accelerating.
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Take the wheel off and jack up the back of the car. Turn the hub round to see if you can hear any scratching or what would sound like a dud bearing. If the rotation is smooth, then your bearings should be ok.
    Other than that, if the car is still under warrenty, get audi to look at it asap!
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    Wheel Bearing, Trust Me
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
    88
    You haven't got my mother-in-law in there, have you?
    Oct 2009
    74
    Do you get the noise in all gears or in a specific gear only?
    Aug 2009
    33
    Quote Originally Posted by gordongecko View Post
    Hadn't thought to check that! Checked on my way into work this morning... still get the same noise irrespective of what gear I'm in.
    I've booked the car into my local dealer as it's still under warranty, so I'll wait to see what they come up with....
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Aww - you just beat me to the mother-in-law joke.....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    Oct 2009
    74
    I was asking because my '08 S3 makes a whining noise in 5th gear only (shift up or down and it stops).. has been in the dealers for a total of over a month last 6 months.. first they changed the driveshaft (made no difference) then they stripped the gearbox and changed the 5th gear, made it slightly better. The whine is still there though and they can't diagnose it and I have given up to be honest as it doesn't seem to be affecting performance or anything. Interestingly the dealer told me that since I highlighted it the dealer has seen 2 other S3s with the same problem (1 customer brought in, 1 dealer heard noise when taking for test drive on unrelated problem).... so seems to be an issue with S3s somewhere, but fifth gear only.
    Your problem sounds like something else, perhaps wheel bearing as already suggested
    Aug 2009
    33
    For anyone who might be interested... it turned out to be the rear diff that was faulty. The dealer replaced this part and the noise went away. The dealer did mention that they had done a number of these on the S3's.
    However... the rear diff was replaced two months ago... it's just failed again!!!!
    A similar noise started about a week ago, and within a week it's now drowning out the radio! It's booked to go back in tomorrow for another rear diff!
