Volks AutosMonster Motorsport
Results 1 to 17 of 17
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    438
    Problems with Comfort Function Auto Window Closure
    Hi people,
    I have this selected via VCDS through Central Convenience and it use to work no problems.
    Recently the driver's side window keeps losing its one touch roll up/down, I keep resetting it by hold the button up for a second once the window is fully up, but it seems to stop working quite randomly.
    Also I seem to have lost the function of auto closure of all windows (dont need to hold button down to close windows when locking) I also cant seem to roll the windows up/down with the remote even if I hold the button down.
    Any ideas welcome....
    Oh the car is an 57 S-line Sportback
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Khufu's Avatar
    West coast of Scotland
    5,693
    How did you end up wiring in your parking sensors? My central locking reports errors despite working fine. Im wondering if it was due to powering the parking sensors off of the convenience module loom. Got the connectors arriving to wire properly via fuse box so i will see if it makes a difference.
    Sep 2009
    Surrey/Hants/Berks
    438
    I ran the power cables down to the fusebox and tapped into the correct slots (just like NHN told me too), CAN was tapped into the convenience module in the boot.
    Khufu's Avatar
    5,693
    mmm, I take it doesnt report a fault either?
    Sep 2009
    Surrey/Hants/Berks
    438
    I dont think so, but I haven't checked recently.
    I'll try to do a scan tomorrow for you.
    Sep 2009
    Surrey/Hants/Berks
    438
    Quote Originally Posted by Khufu View Post
    No fault codes to do with the Park Assist.
    Just checked and in Central Convenience I have the following ticked:
    Byte 5, Bit 3 Comfort Function Power Windows/Sunroof via Rear Lid Door Lock Inactive
    Byte 5, Bit 4 Comfort Function Power Windows/Sunroof via Power Window Switch Inactive
    Byte 5, Bit 6 Comfort Function Automatic Closing
    Byte 6, Bit 0 Comfort Opening Power Windows via Door Lock Active
    Byte 6, Bit 2 Comfort Opening Power Windows via Remote Control Active
    Byte 6, Bit 3 Comfort Closing Power Windows via Door Lock Active
    Byte 6, Bit 5 Comfort Closing Power Windows via Remote Control Active
    Byte 6, Bit 6 Comfort Function After Authorized Access Only for a Limited Time
    Not sure if I have the right Bit(s) ticked ????
    Khufu's Avatar
    5,693
    Not sure, haven't actually looked at these values before. All I changed was autolocking so far.
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,397
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Too activate the auto window function there is a hidden code for the windows.
    I only have a 3 door and i have to do it for each window.
    So start with the passenger window:
    1. Open window fully and hold down for 6 secs.
    2. Close window fully and hold up for 6 secs.
    3. Do this 3x
    Bobs ur uncle and away you go!
    Pii
    Pii's Avatar
    London
    748
    Quote Originally Posted by Cruiser89 View Post
    3. Do this 3x
    Does this mean all windows will automatically close when just you just press the lock button on the key FOB once?
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    No this just activates/deactivates the one touch up and down function!!
    What you are referring to is holding either the lock/unlock button on the fob to open/close the windows. This is activated via DIS.
    Pii
    Pii's Avatar
    London
    748
    Don't have this option in my DIS. Is this the part where the Vagcom comes in handy? I keep reading about comfort functions.....
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Ill take a video when im in my car and post it up!!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    There's a little bit of confusion here I think guys so I'll clear it up.
    The auto-closure function (i.e. using the door controls) is reset by holding the button as has been said. EDIT: This only needs to be done from the drivers side.
    The Byte 5 Bit 6 option allows the windows to close fully from the remote even when the button is released.
    BUT if the auto-closure function stops working the closure by remote function stops also as they're connected.
    The DIS option is only available in MY09/10 cars I think. Mine doesn't have it anyway and the only way to set it on older models is with VCDS.
    If the function needs resetting repeatedly Ryan then you can get Audi to do an update on the door module which should fix it. The same happened to me and it's no needed a reset ever since
    8P2 S3
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    The DIS option on MY10 cars still only allows the windows to be opened/closed with the remote key by pressing and holding, so i'm guessing if you want the one touch function then it still requires you to program this in VCDS.
    I'd quite like the one touch function on mine, but i dont have or know anybody nearby that can do that for me.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Sep 2009
    Surrey/Hants/Berks
    438
    Quote Originally Posted by Staz View Post
    Thanks Staz,
    I seem to have my one touch back on the window switch, but the auto closure wont work on the remote (either one touch or holding down the lock button). Also cant seem to roll the windows down whist holding the remote unlock button down
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by ryanstewart9 View Post
    Thanks Staz,
    To be honest I would try getting the module update first to solve the issue of it losing the function and then go from there.
    I'll check which bits I have set when I'm back after the weekend mate though, if no one else beats me to it.
    8P2 S3
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,158
    MY2009 Sportback SLine fitted with DIS and auto wipers. Auto open/close windows via keyfob worked but sunroof did not.
    Mucking around with VCDS, auto open/close windows stopped and never did got sunroof to work on auto open/close.
    Activating auto open/close windows in DIS did not work either. So for past 4 months the auto close feature has been non-operative :-(
    Using Crusier89's procedure (Only need to do it to one "touch to close/open" front window to activate all 4 windows. I choose to use the passenger window):
    3. Do this 3x
    Auto windows now working. :-) Applied same logic to sunroof using position 1. And pleased to say now auto open/closed via keyfob will operate the sunroof and windows.. :-) :-)
    Now need to test if windows+sunroof will close if it rains.
