Sky InsuranceEM Tuning
Page 1 of 4 1234 LastLast
Results 1 to 40 of 144
Like Tree2Likes
Thread: Audi 55reg quattro load vibrating at 2 thousands revs
    bearder2006's Avatar
    Jun 2009
    205
    any ideas as its doing my head in!!!! any body got the same problem ?it goes away at 2 and a half but you spend most of you time at these revs , would main dealer be to exspensive to find out
    JonRola's Avatar
    Belfast
    48
    You dont say if you're petrol or diesel. If petrol the first things I would do is check or replace the plugs and check all the HT leads.
    An engine vibration, like you have described, usually indicates a misfire in at least one cylinder.
    If its diesel then thats another problem - a faulty injector perhaps....
    Jun 2009
    205
    its a diesel mate didn't think that would course it to vibrate though
    Dec 2008
    249
    I've got the same issue mate, getting done under warranty by main dealer, they say its the propshaft
    Apr 2008
    98
    Had same issue on mk5 tdi 4 motion (same car underneath) prop shaft out of balance.
    Hope this helps
    Jun 2009
    205
    fizz could you ask how much it it is to do it please
    Jun 2009
    205
    did it do it mostly in 5th and 6 th and go away after 2and a half thousand revs
    Dec 2009
    155
    At last someone with the same problem! Got my 2006 2.0 tdi quattro 140 a couple of months back and it's doin my head in too. Think it's drivetrain related because it's only there when you put power on an goes away when you back off.
    Got it booked in at audi for a drive with the master tech on the 12th.
    Will let you know how that goes.
    It's really annoying. Hope it can be cured.
    An yea it's mostly 5th an 6th gear right about 70 mph so very annoying.
    And away over 2.5k revs
    Dec 2008
    249
    Quote Originally Posted by bearder2006 View Post
    Yup mine is just like that. Its not going in till the 22nd, will let you know what they charge (covered under warranty though).
    Jun 2009
    205
    were are you both from ? as it would be worth having a listening to one of you cars to see if its the same
    Dec 2009
    155
    I'm from Glasgow area. So probs not close. Its like extra loud diesel engine noise and vibrations through the car.
    ste
    reverse gear
    west midlands
    121
    hi guys got a 2005 tdi quattro with the same problem and its really annoying, would be good if someone finds a cure.
    Dec 2009
    155
    anyone else have this issue?
    is it a common problem?
    Jun 2009
    205
    audi say not but there is a few on hear with it
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    The load vibrates? Or it has a loud vibration?
    Dec 2009
    155
    I dunno. It's just really noisy and vibrating. My mate says he can feel it right up through the passenger seat when I'm drivin.
    It's annoying because it's right on the torque bar so takes away fun of driving a diesel.
    crunchie's Avatar
    Oct 2009
    Inverness
    861
    i have the exact same problem. bougt a 55 plate tdi quattro yesterday and it started doing it on the way home(obviously didnt accelerate hard enough during test drive)
    hopefully wont need a new prop shaft
    Jun 2009
    205
    its a shame mate did you tell the person you brought it off ?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    think you'll find its the dreded 'flywheel'
    Full leather/19"wheels/cruise/
    Dec 2009
    155
    What you mean the dreaded flywheel lol?
    vw754's Avatar
    Nov 2006
    U.K
    1,852
    the 'flywheel' sureley you know what a flywheel is.
    Jun 2009
    205
    it would be the flywheel if you can here a rattle in first gear i think i got told , mine is going in next sat so i will let you know what my problem is fingers crossed
    Apr 2004
    12,357
    Take it to your dealers, there is a known issue with vibration on DMFWs many have had new clutches and flywheels under warrenty
    Flywheel would be my bet for loud vibration
    If you are having problems with your load vibrating in the back, i would think you coul dhave dodgy shocks
    Jun 2009
    205
    but mine is a 55 and is out now, ive rang derby and they say there is no problem with them guess they would say that
    Mar 2010
    14
    I also have same problem car is tdi 4motion golf
    This is what vw manual says about refitting prop shaft
    If droning noises occur during travel, note the following: t Remove balancing nut and balancing washer -arrows-.t Then, if necessary, unbolt propshaft with flexible coupling from propshaft flange of rear final drive and offset it by one hole.t If droning noises are still audible, front propshaft must be rotated one more hole.
    Im thinking about changing intermediate bearing and getting shaft balanced while off
    So will be good to see what audi say to you when you take it.
    Jun 2009
    205
    didnt think you could the prop balanced ?
  28. #27
    Mar 2010
    14
    Yes propshafts can be re balanced (check to see if the balance weight have fell off usually two metal plates welded at the rear end) there are a few places that do this also they can be stripped cv joint serviced centre bearing replaced.
    here is one that i found http://www.propshaft.co.uk/
    Found this http://www.driveshaft.ie/faq/#2
    Good bit of info read number 2 (2. The driveline vibrates at a certain speed) this is our problem i think
  29. #28
    Mar 2010
    14
    If anyone is going to remove propshaft both ends need to be marked for position on the flanges so it goes back in the same position ie the propshaft holes and the flage holes go back in same place damper must not be removed from prop and new bolts used info take from vw repair manual
  30. #29
    Jun 2009
    205
    thanks mate this might come in helpfull
  31. #30
    Mar 2010
    14
    I will be looking at my propshaft at weekend to see if i can see any wear if not im gonna unbolt the centre bearing and try move it either way to see if its alignment issue.
    Also waiting to see what dealer says to fizz and latta 1989
    But guessing that there under warranty dealer will just change the whole propshaft for ease i bet the cost is about 1500-2000 from dealers
  32. #31
    Jun 2009
    205
    the price from audi just for the prop was just over a grand
  33. #32
    Mar 2010
    14
    plus vat and fitting would be expensive thats why i thought about ordering centre bearing (100 a guess) taking prop off, and taking prop and bearing to propshaft place getting them to change the bearing and service cv joint plus rebalance (200 a guess) should be as good as new.
    could change bearing and service cv myself, but think while its off worth getting balanced and letting them change bearing as they are the specialists only thing they do so for (200 guess) i think could be a better option.
    would be good to see what audi say to the others first. i have checked your audis and my golf same part number for prop and haldex
    The haldex oil and filter should be changed every 40000 mile (worth checking your history) i also changed my rear dif fluid when i done mine (was a little low)
  34. #33
    JonRola's Avatar
    Belfast
    48
    I must add that it seems that the Haldex oil should be replaced every 20,000 miles and oil and filter changed every 40,000 miles.
    I don't know whether this is the norm but my Audi Service Schedule book covers many models in the 'A' series and it's clarity leaves a lot to be desired.
    I think each model should be supplied with a dedicated service schedule. It's not too much to ask for a car of this quality and price.
  35. #34
    Mar 2010
    14
    latta 1989 how did the drive with the master tech go
  36. #35
    Jun 2009
    205
    im going today so will post later , im also waiting for blatta 1989 come on man lol
  37. #36
    Jun 2009
    205
    well its not the duel mass flywheel its coming from the back told to get my prop reckoned it could be costly though if its not that trying things so ringing round for prices
  38. #37
    Mar 2010
    14
    i think it is the prop i work for a diesel engine company i work in product devolpment we have 30 or so engineers i have spoke to them about this
    as i said in earlier post there are not many parts that make up the prop (two halfs connected by a cv joint a center bearing that holds it to car and a damper)
    I am gonna buy the bearing take it to prop recon place get them to chage this they need to split the two half so there two jobs done (cv join plus bearing) then balance.
    I think that balancing alone is silly for tthe price of bearing and extra work later
    If you want info for removing prop i can email you VW plus Audi work shop instruction (ELSA)
    Could buy a secondhand prop but who to say it hasnt been removed for same issue, as with a new prop still could be slightly out of tolerance i guess
  39. #38
    Jun 2009
    205
    Quote Originally Posted by latta1989 View Post
    did you go mate
  40. #39
    Dec 2009
    155
    Sorry not been on recently. Loads of Uni work.
    The guy seemed like he knew what it was straight away.
    He thought it could be the propshaft bearing??
    Says that they have changed the design of them since. I reckon why this problem only seems to be on 55 an 06 cars so far.
    Going in on 26th I think fo repair so will let you know if this solves problem.
  41. #40
    Mar 2010
    14
    Ok thanks Latta1989 will be good to see if its a fix
    how many mile your car done
