JMB RetrofitsVolks Autos
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 146
Like Tree2Likes
Thread: Audi 55reg quattro load vibrating at 2 thousands revs
  1. #41
    bearder2006's Avatar
    Jun 2009
    205
    Quote Originally Posted by latta1989 View Post
    Sorry not been on recently. Loads of Uni work.
    The guy seemed like he knew what it was straight away.
    He thought it could be the propshaft bearing??
    Says that they have changed the design of them since. I reckon why this problem only seems to be on 55 an 06 cars so far.
    Going in on 26th I think fo repair so will let you know if this solves problem.
    the bearing in the middle ?
  3. #42
    Dec 2009
    155
    Cars apparently only done 40k
    ye apparently. The tech said they made it with some rubber bits or something an they can wear away.
    Didn't totally hear him was too busy drivin while he was talkin lol.
  4. #43
    Mar 2010
    14
    mine done 40000 as well
  5. #44
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    32k on mine and its doing it, hopefully its just the centre bearing as Latta1989 says. can upgrade bearing to 07> item too hopefully.
  6. #45
    Jun 2009
    205
    is hard to change the bearing ? what does it intail ?
  7. #46
    Mar 2010
    14
    Dont think the newer bearing will fit as its not just the bearing thats differant it the hanger ours bolts straight up above the prop on the newer ones the bracket bends down nad bolts under the prop
    To change the bearing the cv needs to be split then pull the bearing off using a bearing puller then new one can be put on, all parts of prop need marking to make sure the two halfs go back in the same position or will need re balancing also need to make sure the prop bolts back on the car in same holes
  8. #47
    Jul 2009
    37
    I'm experiencing a similar problem, but at 1400rpm, it just judders and vibrates.. mines a 54 plate 2.0tdi done 60k
  9. #48
    Jun 2009
    205
    this really is a common problem sorry to here that sarah between us we will sort it
  10. #49
    Jul 2009
    37
    Quote Originally Posted by bearder2006 View Post
    Mines going in to the garage tomorrow, does your car do it all the time or only when hot?
  11. #50
    Jun 2009
    205
    alll the time
  12. #51
    B111COR's Avatar
    St Andrews, Fife
    26
    My 56 plate 170 Quattro diesel with 25k on the clock does this, only just noticed as its the wife that uses it most, 5th/6th gear under load, when it happened, I asked her if she could hear/feel the vibration, yes she says, it does that all the time
    Will get it looked at this week
  13. #52
    Dec 2008
    252
    Well mine went in today & they changed the propshaft. All sorted & no more vibration
    On a side note, the 10 plate A4 they gave me was very nice. Would like to see the start/stop, electric handbrake, keyless start & colour DIS imported onto the next A3
  14. #53
    Jun 2009
    205
    was that under warranty fiz ?
  15. #54
    Dec 2008
    252
    Yes mate
  16. #55
    Mar 2010
    14
    There has to be an easier fix as i said the propshaft is only made up of a few parts (2 halfs joined by a cv, centre bearing and a damper) surely one of these must have failed not all of them its probs easier for dealer to change full prop rather than find the problem
    They would need to strip the cv joint to change the bearing and if they didnt join the prop in exactly the same place they would have to balance the prop which they do not have the facilitys to do same with the damper if they remove the damper they need to rebalance (which they cant do on site).
    So unless the propshaft has been bent or it has always done this from new, i guess it can only be the bearing or damper if i were to remove my own prop i would get it balanced for piece of mind and sake of 60ish
    This is just my thoughts tho
  17. #56
    Mar 2010
    14
    Fizz did the dealers go for a drive with you when u first took your car to them as it seems a bit strange they would have a prop sitting on the shelve unless this is a bigger problem than they letting on
  18. #57
    Dec 2008
    252
    Quote Originally Posted by cassf1 View Post
    No they just took it themselves & when they diagnosed it they said I was lucky as they had one in stock. I saw the original booking in slip and it stated that it was not part of a recall i.e known wider problem.
  19. #58
    Roswell's Avatar
    Jul 2005
    Glasgow, Scotland, UK
    311
    Our 55 2.0 TDI Quattro S-line had this problem. I got it fixed just before selling it a year and a half ago. Again it was the propshaft and it was replaced under warranty.
    2005 - A3 2.0TDI S-Line Quattro
    2008 - S3, Sprint Blue, Buckets, Sunroof, Rear Sensors, BT Phone Prep, Folding Mirrors, Interior Light Pack, BOSE, Flat Tyre Indicator, Phatnoise
  20. #59
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    hi mate, did the bearing fix the vibration? any information would be appreciated. thanks.
  21. #60
    Dec 2009
    155
    cars going in on wed for repair so il find out more in detail exactly what they are doing to the car
  22. #61
    Jul 2009
    37
    I still have my problem which is just turning out to be a nightmare, just spent endless money on diagnostics and got no where!!!x
  23. #62
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    that would be great, thanks very much. sorry to use you as a guinea pig lol.
  24. #63
    Mar 2010
    14
    sarah not sure if yours sounds like same problem i have never heard of one happing at so low revs
    unless ur bearing is loose or completely gone
    what have they tried/looked at?
  25. #64
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Sarah, is your A3 a quattro?
    My mate was sitting in the passenger seat and thought he could feel the car 'vibrating' through the seat.
    Mines FWD so no propshaft etc.
  26. #65
    c_w
    1,061
    It might be the balancing of the propshaft causing the vibrartion, since this is a very specialised procedure they just fit a new one?
  27. #66
    Jun 2009
    205
    it is cheaper if your paying to have yours balanced your self
  28. #67
    Dec 2009
    155
    Collected my car the other day and they have replaced the propshaft bearing. Appears to have cured the problem. Don't get the same noise anymore just the noisy diesel now lol.
    Asked the dealer how much it would cost not under warranty and he said about 400 ish.
  29. #68
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    thats great mate, wont be getting it done at the stealers tho. robbing buggers that they are! thanks for passing the info on!
  30. #69
    Jul 2008
    33
    If you look at the propshaft on the Haldex end, you'll see 3x 12point 10mm bolts that go through a rubber bush that holds the propshaft to the Haldex. On the outer surface of the rubber bush there's metal ring. The metal ring should be able to move slightly, backwards and forwards and return to the center position. This ring is the outer race of the bearing. What happens is over time that ring sticks and siezes causing vibrations when accelerating at about 50-60mph. A new - complete - propshaft is about 900 plus vat.
    HTHs
  31. #70
    Mar 2010
    14
    Mr V i think you are getting mixed up with at the haldex end it sounds to me that what you are referring to is the damper, the bearing is in the middle its on the CV joint between the two halfs of the prop.
    have a look here
    http://www.vagcat.com/epc/cat/vw/GOL...05/53/4004830/
    You need to register but its free
  32. #71
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    had my mechanic inspect the centre bearing but nothing obviously wrong with it. going to order new bearing and fit it for starters.
    will report my findings.
  33. #72
    May 2010
    I have same problem on octavia 4x4, i.e. vibration at 2100 to 2400 rpm accel or decel notably in gear 4, 5 or 6. The vibe is engine speed related so not propshaft balance. I checked with a friendly audi/vw specialist and it seems Mr V had it just about right. A few inches forward of the rear diff is a sort of doughnut with steel outer ring. This is the propshaft damper whose function is to reduce the torsional vibes from the engine. You should be able to grip the outer and move it a bit. If not it is seized. Mine is and it goes to the dealer under warranty later this week. Not sure if it means a new propshaft.
    Just to comment on vibration caused by out of balance propshaft, the frequency will be linked to road speed not engine speed. Back in the days of rwd, this was commonly due to worn universal joints
  34. #73
    May 2010
    Audi Drive Shaft Fix
    Quote Originally Posted by crunchie View Post
    Hi, did you manage to resolve your problems by changing the centre bearing on its own? I had my propshaft changed 22 months ago under warranty and now the problem is back, only I am going to have to pay for it myself now so any pointers would be much appreciated.
  35. #74
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by Robo View Post
    Money been a bit tight recently but i think i'll go ahead with the bearing and donught this month.
    Will post my findings.
  36. #75
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Quote Originally Posted by octadave View Post
    Hi. Did the new donught fix your problem? Garage tried to fob me off with a new propshaft at 1K!!!!
    I'd rather crash it into a wall! :L
  37. #76
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    Got new haldex coupling today, 240 from Audi. Will fit it when im back form the rigs and let you know what the score is.
  38. #77
    May 2010
    274
    Got a 55plate 2.TDI QS aswell, and before reading this I didnt think it was much an issue.. I've got 113k on the clock and counting.
    So its definately the propshaft then..
    Reading this thread it isn't very clear as to what the minimum work is required to fix this, nor is it clear the cost.
    I'm seeing ranges of solutions from changing the bearing only to replacing the whole propshaft.
    I'm not too sure if my car is under warranty, I've only just become the 3rd owner, how can i find out if it is? What invalidates the warranty?
    Costs, again ranging from 60 quid for the bearing to 2000 quid for the propshaft.
    Can someone summerise for the sakes of the thread please?
    I can probably stretch to 500, maybe 750 to get this fixed, but I don't know if this is the only problem with the car! (fingers crossed!)
    TIA
    8P Audi A3 2.0TDI Quattro Sport - what a change from my 1.0L CorsaC!!!
    follow me on Twitter - Jonay1990 for #Photography #Aviation #Mil #Automotive #Subsea
  39. #78
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    113k!! YIKES!!! Mines been doing it since about 30k, its at 40k now. Will be 2 weeks till i get my haldex coupling replaced to see if it cures it. NEVER having another audi thats not under warranty! prices for parts are bearable but the labour is a joke! "vacuumed you car free of charge" my A*SE!!!!!!!
  40. #79
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    GOODNEWS GUYS!!!!! Fitted my new haldex coupling today and all vibrations have gone!!
    Audi part no. - 1K0521307A @ 201 + vat.
    I bought the 6 bolts that hold it on also just to make the job easier.
    Took two of us just under an hour to fit and the best thing is that you dont need to split the prob at the centre bearing either. DODDLE!!
    Thanks to "octadave" who pointed me in the right direction.
  41. #80
    antmax7's Avatar
    sheffield
    300
    is it just a case of unbolt old one slide out,slide new one in and re bolt?
