Volks AutosAH Fabrications
    Jun 2009
    173
    Can anyone help with these faults...
    The ESP light has come on twice (won't turn off) without turning the car off & on again...also the temp needle stayed at 0 even though the car was fully warmed up, after I turned it off & on again the needle went to 90...dodgy sensors? Would it be a good idea to hook it up to a vag com? Thanks
    Apr 2009
    Florida (previously Liverpool)
    655
    It's ALWAYS a good idea to hook it up to a VAG-Com.
    Never any other kind of good idea, when you're diagnosing electronic/sensor-related issues.
    Keith
    JonRola's Avatar
    Belfast
    48
    It does sound like sensor problems but it might not be that complicated. Before going for an expensive system diagnostic give the connections to the temp sensor on the rad a clean. It could save you a few quid.
    Has the ESP light only stayed on twice. The control system can, very occasionally, temporarily switch off the ESP and switching the ignition off and on again will reactivate it. If this problem persists then a diagnostic is recommended.
