AH FabricationsSky Insurance
    33
    S3 oil & filter change
    Hi,thinking of doing an intermediate oil and filter change on the S3 and was wondering how difficult it is to do and also where is the oil filter located on the car and are they difficult to remove ? Any pics would be greatly appreciated. Thanks in advance
    A.T.B Leo
    gingers3's Avatar
    Oct 2009
    218
    its pretty easy to do , the oil filer is a paper element one in a plastic housing , you need a 36 mm soket to get the housing off , ive done mine twice now only takes half hour when you ve done it once , id recommend castrol edge for fsi engines suppose to help with the pcv side of the engine
    S3 , CUSTOM CODE , NON RES MILLTEK , FORGE DV , 19" BBS CK (ANTHRACITE) , GREEN COTTON FILTER , ECS DOGBONE INSERT + EVERY AUDI OPTION
    33
    Cheers mate,whereabouts on the engine is the oil filter - is it easy to access ?
    A.T.B Leo
    gingers3's Avatar
    Oct 2009
    218
    right at the front mate , you need to remove the bottom engine tray and you ll see it
    Aug 2009
    Darvel, scotland
    135
    Quote Originally Posted by gingers3 View Post
    yep castrol edge is the best thats what i use got 8litres off ebay for 56 to the door, S3 Holds 4.6
    GIAC pump & race map WITH CONTROLER, VF ITAKE ,AUTOTECH HPFP,MV DOWNPIPE & MILTEK CAT BK,RS4 REG,UPRATED OEM DV, CUSTOM ENGINE COVER, BOOST GAUGE & POD, H&R SPRINGS, OEM BLACK WHEELS, FORGE CATCH TANK AND WASHER BOTTLE ,RNS-E SAT NAV BLUETOOTH,FLAT BOTTOM, BUCKETS,PRE-FACE TAILLIGHTS TINTS
    Oct 2008
    888
    50 at kwik fit
