Chris NottVolks Autos
    A3TDI
    Nov 2008
    Worcestershire
    116
    Using Lots Of Engine Coolant and Smoking Exessively?
    Hi guys, recently my car has been using lots of coolant and im having to top it up once or twice a week now! I have also noticed it is smoking much more than usual, could these be related? Any ideas what it could be?
    I initially put the smoke down to either the turbo being on its way out (130,000 and still on original) or having milltek turbo back system fitted and not having new map put on as ive heard removing the cat will have affected my current map..however im thinking now it could be related to the coolant issue?
    Any help would be much appreciated
    Audi A3 2.0Tdi Sport - Personalised Plate, 19" RS6 Wheels, Smoked Rear Lights, Tinted Windows, S3 Rear Bumper, Westfalia Detatchable Towbar, Milltek Turbo Back Exhaust System, Hybrid Turbo, BMC CDA Forced Induction, 345mm Front Brake Upgrade, 310mm Rear Brake Upgrade, EGR Bypass, Custom Stage 2 Remap, Cruise Control, De-Wipered, Bose Speakers, S3 Mirrors, S3 Side Skirts, S3 Boot Spoiler...
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Coolant loss is usually linked with a cracked head! Common fault on these TDI engines..
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Mar 2008
    Bradford, WY
    788
    What colour smoke? You need a different map to deal with the fueling if you've got decat/ hiflow cat otherwise will overfuel on a map made for standard setup and obviously cause problems, more unburnt fuel in your exhaust smoke
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by navnayyar View Post
    I take it some tuning company told you that so they could take your money as it`s a complete load of rubbish.
    @ Lance 22. If you are loosing coolant and the engine is smoking either the head has cracked or the head gasket has broken. More likely the head cracked as the oil from the cams in the head is seeping down the cracks into the cylinder head and getting burnt a long with the diesel and water from the coolant jacket. If you are loosing water and oil get the engine looked at quickly as the engine could easily hydro lock it`s self or the head crack completely as it did with me which tends to make a right mess of the engine. If you find you need a replacement engine or head i have some secondhand ones laying around if you don`t want to buy new.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
