Volks AutosJMB Retrofits
Results 1 to 15 of 15
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    DENSO IK24 on K04 @ 1.6 bar
    Does anyone run Denso IK24 on 2.0 TFSI K04 with 1.6 bar boost (~24psi) ? Did you feel any performance gains over stock ones? How is really cold start with them, something like -20c (-4F) ?
    S3 2008, GT3076R 0.64 @ 1.55 bar, custom tubular manifold, Milltek TB decated, Autotech FSI pump, RS3 intank pump, RS4 injectors, RS4 hp rail valve, custom Twintercooler, AWE CCB intake. Forge DV, Forge OCC, LOBA SMF Clutch kit // REVO stage 4 dyno tuned >> 441.4HP, 499NM // H&R springs. whiteline Anti-lift kit and rear 24mm ARB // WOT box // KEI force 10 gunmetal 18'' wheels // Facelift rear lights // tinted windows // LED interieur & exterieur
    Mar 2008
    Bradford, WY
    788
    i thought ik22 are for the 2.0tfsi?
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    People recommend Ik24 as a 2 step colder plug than stock, for high boosted cars. I just want to know if they are worth of install and if they are capable of firing the car on really cold temps in winter
    Mar 2008
    Bradford, WY
    788
    my mate runs ik22 and are fine
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    What boost is he running ?
    Mar 2008
    Bradford, WY
    788
    revo stage2 not sure what boost, id say its 1.6bar
    Phantom black S3/
    Mar 2009
    137
    Good question, ive been considering them for a while now...my mate on his astra opc had them installed and said it was much better...
    Phantom Black S3/ APR stg 2+ / Forge CAI / APR HPFP / Miltek TBE / Forge DV / Forge Catch Tank / Forge T. body / VF Engine mounts / ECS EM / KW V3 / 19" BBS CH "Black" / 18" Team Dynamics Motorsort / Denso Iridium IK24 / Forge Twincooler / Helix Race Clutch + Flywheel / H&R ARBs / JVC Multimedia + TV Tuner / Kicker sound system over 3,000W RMS / TT-RS Steering wheel / Whiteline Anti-lift kit / Brembo Porsche GT2 BBK / soon: RECARO POLE POSITION SEATS,
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    I ordered them, we will see how they will play on my car
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    where did you order them from
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
    warren_S5's Avatar
    Oct 2007
    7,166
    I've been running NGK Iridium BKR8EIX (which are 2 steps cooler than the 6's that are recommended). This is with stage 2 set up.
    Cold start is OK, but a bit patchy with the car idling a little rough. Once you are up to temperature and giving it the beans it feels very good (almost like the extra boost isn't hurting the car so much).
    However I was talking to someone about it last weekend and they said if an engine is running properly (e.g. modified, but within reasonable parameters) you should never have to deviate from the recommended heat setting, only upgrade the plug used.
    Urban legends, opinions, myths.... who the hell are you supposed to believe???
    Audi S5 3.0V6T Coupe Black Edition
    KRL
    KRL's Avatar
    Jul 2007
    523
    I am interested in this topic as I believe my spark plugs could be causing a flat spot I am experiencing at ~4400 rpm.
    The plugs I was looking at getting are these ones which are 1 step cooler than stock:
    NGK IRIDIUM IX spark plugs - BKR7EIX
    http://www.jkm.org.uk/performance/tfsimisc.htm
    My car has covered 28k (8k of them at stage 1) so I think it is probably time for a plug change anyway as they have not been changed yet.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Quote Originally Posted by A3simon View Post
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Quote Originally Posted by warrencox View Post
    First I will try with IK24, if everything will be ok then I'll leave them, if not I'll put IK22 (I ordered them also just in case)
    Iggu's Avatar
    May 2008
    Here
    1,224
    You might find my write up on these here of interest: http://www.vagoc.co.uk/vb/showthread...hlight=iridium
    Phantom Black S3, RNS-E with SDS Hack , BOSE, Sunroof, iPod, ITG CAI, Forge DV, Milltek TBE, Revo Stage 2+, Autotech HPFP, Sachs clutch, Lamin-X, BBS Pescaras, H&R springs, H&R ARBs, NGK Iridium Plugs, Vagcom.
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Quote Originally Posted by Iggu View Post
    Great ! Good that I ordered them !
