Sky InsuranceAH Fabrications
    scottie123's Avatar
    Oct 2008
    1,888
    location of central electrics module?
    Anybody know where it lives in the 8p? And what is the best way to get at it.
    Also, would it be pushing my luck to ask what repair wires would be needed to add pins to connectors A,D and E ?
    05 SB SE BKD
    Build Thread
    JohnS3's Avatar
    Oct 2004
    3,021
    It's under the drivers side of the dash. Take the cover off the fuse box, remove the bolt (There's two more underneath.) that holds the lower cover around the headlamp switch. Look under the dash and you'll see a large box with many plugs in it. This is your CE unit.
    JohnS3's Avatar
    Oct 2004
    3,021
    The repair wire is probably 000 979 009. One repair wire has a plug on both ends.
    scottie123's Avatar
    Oct 2008
    1,888
    Thanks John.
    05 SB SE BKD
    Build Thread
