Results 1 to 10 of 10
    david_phillips95's Avatar
    Nov 2008
    538
    S3 8P Video Of Clutch & DMF Removed From My S3
    My car had covered a grand total of 19k miles when this gear was removed, the clutch started slipping a few months after stage one remap. If your clutch is slipping your DMF will most likely be flapping around as much as mine is in this video lol
    Cheers Davie
    Oct 2009
    Aberdeenshire
    192
    think you have posted the wrong link
    Nov 2008
    538
    fixed, too much copy and pasting going on
    Davie
    Oct 2009
    99
    I've just had a play with my 'new 'flywheel which is in my living room waiting to be fitted and has the same amount of movement as your old one !!!!
    Alarm bells are ringing !!!!
    Nov 2008
    538
    when you say its "new" where did you buy it? if yours is anything like mine i would be very worried lol
    Davie
    A4_DTM's Avatar
    Dec 2006
    Croatia
    97
    Flywheel has to be in that condition, that is normal, flywheel is damper in whole system because clutch has no springs on it ! SMFW system has springs on clutch so clutch is damper.
    S3 2008, GT3076R 0.64 @ 1.55 bar, custom tubular manifold, Milltek TB decated, Autotech FSI pump, RS3 intank pump, RS4 injectors, RS4 hp rail valve, custom Twintercooler, AWE CCB intake. Forge DV, Forge OCC, LOBA SMF Clutch kit // REVO stage 4 dyno tuned >> 441.4HP, 499NM // H&R springs. whiteline Anti-lift kit and rear 24mm ARB // WOT box // KEI force 10 gunmetal 18'' wheels // Facelift rear lights // tinted windows // LED interieur & exterieur
    Phantom black S3/
    Mar 2009
    137
    Quote Originally Posted by A4_DTM View Post
    Thats true....
    Phantom Black S3/ APR stg 2+ / Forge CAI / APR HPFP / Miltek TBE / Forge DV / Forge Catch Tank / Forge T. body / VF Engine mounts / ECS EM / KW V3 / 19" BBS CH "Black" / 18" Team Dynamics Motorsort / Denso Iridium IK24 / Forge Twincooler / Helix Race Clutch + Flywheel / H&R ARBs / JVC Multimedia + TV Tuner / Kicker sound system over 3,000W RMS / TT-RS Steering wheel / Whiteline Anti-lift kit / Brembo Porsche GT2 BBK / soon: RECARO POLE POSITION SEATS,
    Nov 2008
    538
    My DMF was inspected by a fully qualified Audi Master Tech, you are allowed rotation upto 3-4 teeth but the play in the plate is means it needs replaced. so no way is that normal! Why would i spend over 600 replacing it if it was fine??
    Davie
    Oct 2009
    99
    Got it from here Davie- http://www.autospares-group.co.uk/luk-clutches.php.
    I have never had anything to do with DMF's so i dont know if its normal or not ,im gonna take it to my mate who will be fitting it ,i trust him with my life so if he says its good then thats good enough for me lol !(he owns his own garage and has fitted loads)
    Ill report back later ......
    SILVER S3.......GIAC ECU & FLASHLOADER.....ITG INTAKE.....SACHS ORGANIC CLUTCH........ROLLING @ 328bhp...321lbs/ft
    Nov 2008
    538
    Quote Originally Posted by mrgicm View Post
    Thats true....
    what a load of nonscence, you obviously have no idea. How can a DMF that has collapsed be serviceable???? this is the reason my clutch was slipping not because the clutch was worn out. You can see and hear the inner plate of the DMF rocking in the video, tell me how can a clutch securely clamp to a plate that is rocking....the answer is it CANT the clutch will slip as it cant clamp 100%
    if anyone believes this nonscence i will be more than happy to sell anyone my perfectly "normal" DMF for a bargain price of 50.00
