Volks AutosJMB Retrofits
    41
    Are Edinburgh Audi trying to rip me off......
    I had my car in getting its Quattro oil change and they ran a diagnostic on it - i got a note back when the oil chnage was done saying that there may be a fault with an exhaust gas pressure sensor but they would need to run another diagnostic to confirm @ Ł58 + VAT.
    I have since been using the car and it now has an intermitent fault that it starts to run rough and lose power for short periods of time - Audi saying this is the pressure sensor failing - never happened before it went in.
    No they want Ł300 to do the job - Part is Ł42.11. 2.5 hrs to do job Ł85.00per hr + vat += Ł299.17
    Can i get this done cheaper at another garage or am i better of getting the part and then asking a small independant gargae to fit it?? The car is out of warranty anyway so why stick with them? Thoughts welcomed.
    Jun 2003
    World of my own
    9,813
    Find a decent VAG specialist, they use OEM parts (but cheaper as they aren't stamped with the expensive 4 rings) and will be half the price on labour.
    Alex Turner
    Give Star Performance a call in Fife on 01592 655595.
    VW/Audi specialists and are waaaaay cheaper usually.
    Jim or Brian will help you out there....
    Quote Originally Posted by AndyMac View Post
    Whoever does any work on your car, if they use non-Audi (true OEM) parts that will void any warranty you may have.
    Dave R (h5djr)
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Quote Originally Posted by dobber View Post
    Forfar (outside Dundee) may be too far for you to go but try giving Sandemans Cars a call, they own all the manufacturers diagnostics software for merc vag and ford, fairly cheap hourly's too. ive seen them take on massive jobs too
    the number is 01307463483
    and they use oem parts, my vagcom tells no lies
