Chris NottSky Insurance
Results 1 to 19 of 19
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    Deteriorating fast now..
    My A3 3.2 is going down hill fast now. On start up it will, 1 in 5 mornings tick over on 3 or 4 cylinders, revs will bounce between 0 and 500 rpm. the only way to stop this is to switch off and re start. Now its started doing it between 0 and 3 miles down the road. You just have to pull over, switch off and re start.
    It is showing no fault codes.
    Audi say no fault codes, no problem ( a polite way of saying P** off) and i cant afford to pay them 150 an hour to search for a fault they don't believe exists anyway. I take it in, they give it back with a note saying " no fault found"
    Once warm it will run all day and not miss a beat.
    any thoughts ??
    Low life livin' the high life.
    Feb 2008
    1,638
    Just goes to show that the art of being a car mechanic is slowly dying. They're just computer operators nowadays. No common sense.
    Any mechanic who knew a thing or two about cars and specifically VAG engines would know what the problem was without VAGCOM to tell him.
    Poor show.
    A3 2.0T FSI Quattro S-Line, 3 Door, Avus Silver (special ed.)
    For Sale:
    S-Line gear knob, stick and gator.
    Full set of OEM wheel bolts (incl. locking nuts & caps)
    19" BBS CK's Anthracite - SOLD
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Yep VAG specialist is a good idea I agree.
    You could always make arangements to leave your car in their carpark overnight and then meet a tech in the morning when you start up.
    Do you have VCDS Paddy?
    8P2 S3
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Yes i have run a fault code check and run several blocks tests but it dosnt even register a misfire when on 3 cylinders and struggling at 250rpm.
    this is Audi's response.....you see its supposed to pop and bang at a steady 2k revs...no fault code...no fault.
    Trouble is Audi employ technicians not mechanics. they can down load a fault code but thats about it.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I can't believe that it doesn't log a fault for a misfire! Mine misfired once a while back and the log showed me which cylinder it was on, at what point on the odo it happened and even the speed I was doing! I didn't even know it had happened.
    8P2 S3
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    It did show a fault code once a couple of weeks ago but stupidly i cleared it and since then it has got much worse and hasnt logged another code
    8 Faults Found:
    18025 - Glow Plug Pre-Heat Indicator (K29): Open or Short to Ground
    P1617 - 001 - Upper Limit Exceeded - Intermittent
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 008 - Implausible Signal - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 002 - Lower Limit Exceeded - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 008 - Implausible Signal - Intermittent
    16690 - Cylinder 6: Misfire Detected
    P0306 - 008 - Implausible Signal - Intermittent
    16686 - Cylinder 2: Misfire Detected
    P0302 - 008 - Implausible Signal - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    can't believe how many people seem to have problems with this engine on here, guessing the R32 is similiarly affected?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    pluves1's Avatar
    Dec 2008
    353
    I would suggest that if you want Audi to investigate you can't go clearing the fault codes and not tell them. They will be correct in that it isn't logging what you have suggested as you've cleared them!
    As it happens on a morning or start up why dont you leave the car with them overnight to see if they can replicate the issues you're having first thing? You'll also need to be more specific when the fault is occurring. There is no mention on the check list that this is on startup.
    Sorry if this doesnt sound helpful but, you either leave Audi to try and diagnose fault or do it yourself - I dont think its going to get resolved if you are 'tinkering' in between.
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    pluves
    This has been going on for months. Audi have washed their hands of it so my "tinkering" is my only option short of scrapping the thing. belive me ..if audi could fix the thing i would not be "tinkering" myself.
    the car faults most mornings at some point. I cleared one set of fault codes a few weeks ago because audi pulled the plug out of the MAF when the engine was running so the codes above were not reliable. Other than that it does not register fault codes.
    Audi say that with no codes then an engine strip or basically testing all circuits from fuel system to ignition ( which might not actually reveal the problem) is their only option. this could run into thousands and not actually solve the problem.
    pluves1's Avatar
    Dec 2008
    353
    As it faults 'most' mornings I'd leave it with Audi or an Audi specialist so that they can try and replicate the issue.
    Now
    Previously
    edition's Avatar
    Nov 2007
    1,417
    At least if it's looking like it's getting worse you should find out whats up sooner or later.....
    Akash, I don;t think this is a problem alot of people are having with the 3.2!!! I mean if they were all running like that I think there would be more uproar!
    Hopefully you get a simple fix Paddy.... Quite likely that it could be something simple! It's jsut finding it.
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    You are right Jonathan. Up till now the problem has been to random to leave it with Audi but its getting worse now....I just wish it would leave a valid fault code.
    edition's Avatar
    Nov 2007
    1,417
    Yeah bit of a bugger it's not show faults!
    It does look like you are going to find a fix though now it's getting worse...
    One would think it's an electrical issue due to the fact the restart sorts it out.
    Khufu's Avatar
    West coast of Scotland
    5,693
    It's the glow plug error I dont get! Something hasn't been coded to tell the car it's a diesel & hence why its reporting a fault with the glow plugs?
    Jan 2004
    York
    1,657
    <rant>
    Sorry am I missing something. You say that Audi have washed their hands of it ? No they haven't.... they have just said they need a closer look and that would take some time.... so that time has to be paid for. You can't expect everything for free !!! You got a vehicle scanned for free which should have been about 45 - 50 ish quid from a main dealer. </rant>
    On topic though
    I would say it's probably coilpacks ......
    MY15 8V S3 Sportback with options
    edition's Avatar
    Nov 2007
    1,417
    Let's not let this slide into slagging or sticking up for Audi....
    Yes coilpacks are a simple one to have ago at and don't always show up on the scans... might be worth ago at buying 6....
    Jan 2004
    York
    1,657
    Quote Originally Posted by edition View Post
    No offence mate, but the beauty of the internet is everyone is allowed an opinion. And for all the responses so far, it took 15 posts to give the guy and idea at what to look at.
    edition's Avatar
    Nov 2007
    1,417
    No offence but he wasn't asking peoples opinion on Audi......
    And if you had read previous threads he has had LOTS & LOTS of info. on what it could be....
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Post
    Auroan,are you an angry man ? less of the baiting please.
