    132
    Wing mirror cover - 2006 A3
    I'm trying to take the wing mirror casing off the drivers door mirror on a 2006 A3.
    The current one is cracked and I want to replace it with a new one, but don't know what to do. I tried a search but can't find anything.
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
    Oct 2008
    Telford
    2,488
    Pull the mirror glass itself down from top to bottom, you will feel some resistance on the motor but dont worry, they are deisgned to do that!
    Once its fully pulled down you will see 2 mounting points with slots in them. Using a flat bladed screwdriver you should be able to open these clips up. Once you have 1 done chances are you can just pull up. Pull the mirror cover up vertically else you will snap the clips.
    Job done! It doesnt feel right but thats the proper way, after all, they arent designed to me messed with yourself!
    B6 1.8T Avant s line gmbh
    pns2007's Avatar
    Nov 2008
    627
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Oct 2008
    Telford
    2,488
    Quote Originally Posted by pns2007 View Post
    Yeah first one is not the same but the second one, audizine is nearly identical to the A3
    132
    Thanks, will let you know how it goes!
    A3 3.2 S Line DSG
