JMB RetrofitsBadger5
Results 1 to 21 of 21
Like Tree3Likes
  • 1 Post By Audi-Rog
  • 1 Post By Jbelly
Thread: New Diverter Valve 'D' installed!
    Audi-Rog's Avatar
    "Fire up the Quattro!"
    Dec 2009
    Milton Keynes, United Kingdom
    168
    Add Audi-Rog on Facebook
    Had the common problem with the DV on a 2.0T FSI remapped engine (after installing a K&N panel filter).
    I felt a sudden loss of boost (and whistling like a kettle!) whilst trying to pull away from a Focus ST (Mk2)
    So after a search on here, I decided it was the DV with a split Diaphram that was to blame. So ordered a new upgraded 'D' type DV to fit myself.
    I can tell you this looks easy and simple enough on paper but by 'eck it ain't I'm not too bad with cars and have changed most things on my previous cars.
    This was tricky and fiddly! It was very tight to get at and the bolts took ages to undo as the wasn't much turning space and my big hands didn't help. So after loads of managed to get it swapped over.
    After checking the original DV found it had in fact split, which was a relief after all that effort getting it off. Plus the cost of the new DV not going to waste! It's worth persevering and was alot easier to get back on.
    You will need a 4mm allen key, torx set/driver (T30) and small ratchet set and a nice hot bath/shower to relieve the serious amount of aching and pulled muscles , plus lying on the ground when it was snowing ,hailing then sunny then hailing again didn't help
    Then I took it for a test drive, it's like I'm driving someone else's car. Now it feels like it has been remapped! Where as before it was quickish but didn't feel any quicker than my Anniversary Golf with only 180HP.
    If anyone has the same symptoms and their car feels underpowered and you can hear your Turbo whistling from in your car with the stereo on!! Then it could be your old DV splitting. ( on TFSI cars normally before 2006)
    The upgraded DV part Number is V06H 145 710 D and cost -50.29 Inc VAT. And is the only type available now anyway, so you can't go wrong!
    So, thankyou Audi-sport.net for the info it really did help
    Maybe someone might get some help from my experience.
    Rog
    Jbelly likes this.
    |Audi S4 B6 4.2 V8..gone|A3 TFSI Q S line..gone|
    |Current: Audi A3 3.2 V6 DSG
    S line|BBS Carlitos|
    |K&N Panel Filter|Superchipped 265 BHP|
    |Link
    :FREEMAN:detailing Milton Keynes|
    Oct 2009
    99
    Pick mine up tomorrow !! For S3 though so 2 min job to change lol
    Audi-Rog's Avatar
    Dec 2009
    168
    Good luck mate!
    But doesn't the S3 already have the upgraded DV?
    Rog
    P.s. I been thanked too
    |Link
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    there is an uprated s3 DV, that is stronger than the old one.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Audi-Rog's Avatar
    Dec 2009
    168
    Are you talking about the Forge DV?
    If it is an Audi DV, do you know the part number?
    As I thought this was the same as the part I've just bought!
    Or has it got a stronger Spring/piston to take the KO4 turbo?
    Rog
    |Link
    Oct 2009
    99
    http://www.jkm.org.uk/performance/Mi...NewDV2_big.jpg
    This is the link to the uprated oem dv. Its basically the same,they have removed the diaphram which was prone to splitting and its the same valve used on all the 2.0 TFSI engines not just the S3 (i believe).
    My S3 is a 07 plate and has the old type dv and because its remotely located on the front of the engine its a doddle to fit :-) .
    Hope this helps.....
    Aug 2005
    London
    263
    As I'm lazy and can't search easily on my crackberry, where is the DV located on non-S3 TFSI engines?
    Any pics?
    Oct 2009
    99
    90% sure its bolted directly on the turbo at the rear of the engine hence why its awkward to change.
    Aug 2005
    London
    263
    And is it only accessible from under the car?
    Oct 2009
    99
    I believe so but not 100%.
    Im sure there will be some post on here with some info.
    Audi-Rog's Avatar
    Dec 2009
    168
    Quote Originally Posted by davej_anderson View Post
    I'm no mechanic and I'm sure there is some other way!
    However the only way I could see to get to it was from underneath the car, if you had ramps/lifts or a pit and an endless assortment of tools then it would be a very simple job to do! But I don't, hence the headhache (and back/neck and arm ache!) fitting it!
    The bolts are quite awkward to get at which makes it a bit frustrating, if like me you haven't any patience!
    Here is a picture of the old (left) and new upgraded DV:
    And here is the DV in Situation( view from under the car):
    Here is a link showing how to fit the Forge Blow off Valve so should help fitting the New type DV.
    http://images.google.co.uk/imgres?im...3D189%26um%3D1
    HTH
    Rog
    Jbelly likes this.
    |Link
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Does anyone know if these can be replaced under warranty even if it hasn't split yet?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    don't think so...but it around 50€
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    i did mine on the A3 when i first bought it 4 years ago and i found it fiddly but more than do-able on the driveway.
    suprising how its 50 now because mine was 25 from Audi!
    cameron1's Avatar
    Mar 2009
    56
    I found it a nightmare to change when I did mine a few months back (but I am a kack handed fool). I found it easier getting at it through the wheel well mostly.
    My original DV was noisier, but it wasn't actually split so I didn't notice any increase in performance when I changed it for the Rev D version.
    2.0Tfsi Quattro S-line + remap
    Aug 2005
    London
    263
    Does anyone know from which year the new type was fitted before I clamber under the car to find out if I have the old one?
    Audi-Rog's Avatar
    Dec 2009
    168
    Well I have an 8P1 2005 TFSI engine and that had the old DV. If the DV is on the turbo I would say it may possilbly be the old DV, as the newer TFSI's, S3's and ED 30 Golf have the DV situated at the front of the engine bay.
    I read that anything from 2006 should of had the new upgraded DV fitted. But then someone had the old DV on their 2007 S3, so.... the only real way of knowing is to take it off to check.
    Somebody else may/will know more I would expect.
    Not conclusive but it may help you,
    Rog
    |Link
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    my car is MY09 7 months old, and it has old DV. i think that MY10 has new uprated DV.
    Dec 2013
    Southampton
    51
    Cheers for the info guys I changed mine today, there was nothing wrong with mine but thought I'd fit the upgraded valve as preventive maintainance :-)
    I had a quick google search and this thread came up, my heart did sink when I read about the access but tbh did find it too bad although I do have a good selection of 1/4 and 3/8 sockets and extensions from my old R5 GTT days :-) I found the most annoying thing was the plastic liners being quite sharp :-( lol
    Audi-Rog likes this.
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    226
    Hi guys.
    I can recommend this one. It's better than the OEM piston Rev D valve to :-)
    Go Fast Bits DV+ Diverter Valve (2.0T FSI & TSI Engines) - Modded Euros
    Best regards
    J$B
    Norway
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Bought from GSF Nov 2012:
    DIVERTER SOLENOID VALVE Item Number 929VG0930 £46.38 incl VAT and Del.
