Chris NottAH Fabrications
    NE1
    12 Month used car warranty & work to do - Help.
    Hello,
    After a little advice here, if poss......
    Following a "free MOT" local dealers have identified on a "visual check" that the following work needs done and at this price
    Brake Fluid Replacement time/mileage Ł56.39
    ft pads n discs corroded Ł279.51
    rr pads n discs corroded n binding Ł225.84
    x2 intercooler seals oil leak Ł71.86 amongst other work
    If i get this work done elsewhere (none Audi dealer) will it void the reminder of my Warranty? Car has just had its second variable service and has 25k on clock. A3 2.0 TDI S-Line 140
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    'm 99% sure a ruling a couple of years ago means as long as a VAT registered garage is used and you keep the invoices as proof then warranty is still valid - this was to stop main dealers having the monopoly on work
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    When i had front pads and discs fitted to my TT225 i bought genuine pads at Ł59.00 and Lockhead discs at Ł69.00, fitting was done at a friendly garage for Ł20.00 so i think Audi are overcharging
