Results 1 to 7 of 7
Thread: Lack Of Power
    jacko
    Lack Of Power
    When driving my A3 2005 2.0 TDI everything is ok until i get to motorway or when overtaking. Then my engine power dies making it impossible to accelerate unless i stop car and turn off engine and restart car,then all is ok till the next time it happens. Any Ideas what problem is?
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    You need to get somebody to scan your car with VAG COM as your car is going into limp mode for some reason.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    leach76's Avatar
    Feb 2009
    sheffield
    305
    Normal causes are normally : maf sensor,boost reg or selenoid,turbo vanes sticking,but wouldnt think turbo vanes if it is curing once the igntion is turned on and off
    Unhappy 2005 A3 SE TDI 2.0 140 bhp Sportback, same issue
    Quote Originally Posted by jack009 View Post
    Yesterday I noticed the same issue Have you figured out why your engine losses power yet?
    I'm going to get a VAG COM asap...
    ok,
    there is my log below:
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - -
    Freeze Frame:
    RPM: 2520 /min
    Torque: 138.0 Nm
    Speed: 132.0 km/h
    Load: 32.2 %
    Voltage: 14.52 V
    Bin. Bits: 00101000
    Absolute Pres.: 1499.4 mbar
    Absolute Pres.: 2182.8 mbar
    Readiness: 0 0 0 0 0
    any ideas what I have to do now?
    Feb 2007
    1,257
    The turbo is over boosting for some reason. Usual suspects are the VNT turbo vains sticking,actuator rod sticking or a faulty N75.
    ok. in my case it was one of vacuum hoses. just fell off.
