any body local to me im in rugby warwickshire and need to plug my bi-xenons into a car which already has them fitted so that i can centralize them before i fit them.
i havn't got leveling system so i need to plug them into a car which has and set them in mot mode using vag com and remove them again....the lead that powers the lights is long enough for my lights to sit on the engine bay while this is done...
Right he may have had to but that's not necessarily the case with yours. Chances are if they came off another car they'll already be about right. Do you have manual levelling in yours?
yes i have manually levering but that will not work onc fitted. the idea of fitting them in a donor car that has xenons fitted is that using vagcom u set the lights into mot mode and then unplug them which locks them at the rite height
No, IIRC MOT mode just lets you adjust them when it's plugged into the car. If you don't have a levelling circuit connected you can just adjust them as normal.
I know your levelling circuit won't work but you can make it work but swapping the motors and wiring.
