Volks AutosJMB Retrofits
Results 1 to 14 of 14
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Best H11 FOG LIGHT BULBS Suggestion please?
    As stated in title, Just wondering if you guys/girls have any suggestions as to what are the best resonable priced bulbs and emit the XENON type look to match the main beams?
    Did a search and couldn't really find nout.
    There used to be a thread on here where there was a "group buy" for different light bulbs but since the change over in appearance, I can't find it on the search
    Cheers in advance
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    No one replaced these at all with better ones?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    think that PIAA makes them.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Quote Originally Posted by S. View Post
    Have you got these personally? If so what do you think of them?
    Synchromesh's Avatar
    Will Race For Cookies
    Jun 2009
    Belgium
    99
    Ik have the Hoen Xenonmatch 55W H11 bulbs in my A3, they are pretty close to the oem 4300k xenons.
    http://www.hoen-usa.com/fog.htm
    Post 15: http://www.audizine.com/forum/showthread.php?t=309928
    Phantomschwarz Audi A3 2.0 TFSI quattro S-Line | Bilstein PSS B14 | Oem 8x18 ET43 5-Spoke | Facelift taillights | RNS-E MKII | My Thread
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    no i don't have them. i actually think that fog lights are like that for reason. but i think madalex had them on his s3 (use search for pics), and it looks quite good.
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Ok cheers for the info guys.... I think there needs to be thread created in the "Look her first" sticky with this sort of thing as I searched and didn't find anything
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    You won't find any normal bulbs that are the same as the xenon beam as they're obviously not xenon bulbs
    Only way would be to install an aftermarket HID Xenon pack into the foglights
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Quote Originally Posted by smudge_don View Post
    I wasn't after xenon beams I just wanted matching colours rather than the stained yellow look which looks off key with the xenon set up...
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    As S. has mentioned I think fronts fogs are meant to be off-white (different temp) to reduce the reflection and enable you see, and be seen, easier in fog. For the amount of time it is foggy in UK (especially London) I can't see the point...I mean it's not like you will be driving about with them on when it's not foggy.
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Quote Originally Posted by AuldReekie View Post
    Yeah this is true, but one of the bulbs has blown and since I need to replace one might aswell do both and match up with the xenons while I'm there
    AuldReekie's Avatar
    Feb 2009
    UK
    766
    Quote Originally Posted by 330_2_S3 View Post
    Gotcha now. Well I used these guys for PIAA DRL and side replacements, maybe they can advise better. I am not sure I have seen many threads on here about swapping out the foggies, but these ones on the link below are H11.
    http://www.priracing.com/product.php...te-bulbs--pair-
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    Cheers mate will look into it that bulb out warning light is pi**ing me of hard!!!!!
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    gotta be carefull though because if you fit the bulbs that have a blue coating and they say they give a whiter light and its brighter, yea it will be whiter and be more of a match to that of a xenon bulbs, the lights will be rubbish, the blue tint traps in a lot of light and temperature. ur best off fitting osram night breakers, wont give you a good match but will be slightly brighter and you get better vision. the extreme white ones you get are purely for show.
    the nightbreaker have a light blue tint at top and bottom of bulbs leaving a clear section in the middle, it moves the temp to about 2700k to 3000k but keeps the performance of bulbs, where these extreme white ones move the temp to like, 4500k
    http://www.autobulbsdirect.co.uk/h11-bulbs.html
    Last edited by gixxer600k4; 8th February 2010 at 11:45. Reason: shocking spelling!
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
