OK, so I finally got around to getting a couple of mods done photos to follow (when I can work out how to add them):
Ive fitted H&R spacers front and back (bought these from mitch78 - thanks again!). From memory the front were 10mm and rear 15mm.
Ive also had fitted 35mm H&R lowering springs. I was hoping for a bit more of a drop over my old std S-Line springs but cant afford coilovers right now hopefully itll settle a bit lower anyway.
However, on the rear passenger side Im getting an occasional noise over some bumps which I presume is the wheel rubbing somewhere on the arch. I only have standard 18 RS6 style wheels, (225 tyres, not sure of the wheel offset) and this doesnt happen on the rear drivers side...
I havent yet had a full 4-wheel alignment done. While I will get this done surely the wheels cant be far enough out of alignment to cause the rub? 15mm spacers and the 35mm springs seem a common mod but I dont think Ive read other reports of rubbing.
Any ideas?
MG
Any ideas?
MG
