Volks AutosChris Nott
    34
    [Help] LED light's on the interior door handle
    Hello.
    I've been thinking of installing a light on the interior door handles of my a3. I've been searching and i saw that there is a different door handle with the lights and that is necessary to change the current handle. But, isn't it possible to just install a red led there and make a small hole on the top of the handle so the light can come out? Has anyone done this?
    Also, i would need to take apart the hole door panel to do this or i can just remove the door handles? Because if i have to take the whole panel out i probably won't do it because i don't have enough experience to do this and im afraid i would mess something up or wont be able to put it back again
    PS: Sorry for any mistake on my english because it's not my native language.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Welcome to the forum. Dont worry, your English is better than a lot of the 'English' here at times LOL
    Have you looked at this thread?
    http://www.audi-sport.net/vb/showthr...D-Lighting-Kit
    34
    Thanks.
    I didn't know about that thread and just finished reading it. So it is possible to do it without buying the new handles, but what i didn't understood was if it is possible to take just the door handle or not =/
    pns2007's Avatar
    Nov 2008
    627
    In my experience of fitting the door warning lights and puddle lights to my A3 and now my A4 you will still need to remove the door cards so that you can wire the door handle illumination lights into the door control module. There will be two pins you need to connect two (I don't know which until I look into the wiring diagrams in elsawin)
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    447
    Quote Originally Posted by pns2007 View Post
    Sorry for hijacking the thread.
    pns2007, can you tell me where to find the wiring diagrams in elsawin as I'm having trouble locating them?
    I'm looking for a wiring diagram of the fuse box and relays.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    pns2007's Avatar
    Nov 2008
    627
    Look in the current flow diagrams (yellow triangle), type in your vehicle details and then search 'driver door opener' (page 13 on the one I looked at) and scroll through to find the correct diagram (which was No 51/17 on the one I just looked at). The bulb was listed as L108 and the pins were 17 (+ve) and 19 (-ve). This was for a 2009 A3 8P1 diesel I looked at. They may well all be the same but check. You will need to do the same for the other doors.
    Hope this helps
