Monster MotorsportVolks Autos
Results 1 to 8 of 8
Thread: Xenons
    tdi-man's Avatar
    Jul 2009
    1,611
    Xenons
    thinking of putting xenons in my a3 the single bulb sort not bi ones do i need an adaptor lead does any body noe any one in uk that does this lead ?
    thanks
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Khufu's Avatar
    West coast of Scotland
    5,693
    The standard xenon's are a direct fit, you just need to use vagcom to tell the car it has them.
    tdi-man's Avatar
    Jul 2009
    1,611
    oh right thats good news then i have vagcom ..can you adjust the height of them with vag com as im not installing the auto levelers
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,971
    dont they pop the wiper motor?
    Full leather/19"wheels/cruise/
    Jun 2009
    173
    I think only fake HID's pop the wiper motor.....hate them with passion
    tdi-man's Avatar
    Jul 2009
    1,611
    no thats the aftermarket hids....
    i just bought a set of xenons so need some help any body local with single xenons that i can plug mine into to set them to mot mode ......
    thanks
    Khufu's Avatar
    5,693
    You cant adjust the height using vagcom (even if you can?) as you dont have the module that controls the height installed. The module also wouldn't work right without the leveling motors installed either. There will be the normal adjustment screws, hopefully you can get enough adjustment off of those. I guess you could line car up against a wall and mark off where the lights line up to including the break off point and then when you fit new ones make sure they line up up/down & left right.
    tdi-man's Avatar
    Jul 2009
    1,611
    ok many thanks so i need to plug them in to someones car to adjust to normal height and unplug them while there on....then refit to my car and manual adjust ?
