Volks AutosSky Insurance
    Dec 2009
    Birmingham
    88
    Front seat rear panel removal
    Hi everyone
    Quick question (as you can tell i'm new to the retrofitting scene) can somebody please tell me how easy it is to remove the front seat rear plastice panels, as i want to replace mine with a pair with the attached nets.
    Thanks for your help
    2007 A3 S-line 170 TDI S-tronic
    Brilliant Red, Bose, RNS-e with bluetooth and SDS multi-function, factory fin, Ipod, Full Vienna Leather, interior ambient light pack, non smoking pack, 18" BBS split rim's, cruise control, 09 vents-climate control-switches, Cupra splitter
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Its fairly easy, you just need to literally pull it off. Its held by 4 clips. 2 in the centre and one on each side. Easiest way to do it is to pull the end one off first and then the other end one. You can then pull the panel off from the centre as it has 2 clips there which are about an inch away from each other. Requires some strength...
    JamesS4cab's Avatar
    Mar 2008
    1,091
    - Just won the set on ebay that I am guessing you might have been bidding on..........
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    26,747
    Alternative option would be to buy the slightly smaller nets that are fitted in the front passenger footwells on side of center console & screw these to the rear, which would give you a small net to store something, not as nice but cheaper.
